What's the best suitable enclosure for Faitalpro 8FE200
What's the best suitable enclosure for Faitalpro 8FE200 Please consider donating to help us continue to serve you.
Old 27th November 2019, 04:45 AM   #1
audfrknaveen is offline audfrknaveen  India
Default What's the best suitable enclosure for Faitalpro 8FE200
Hey guys...
My initial plan is to build a two way ported BS with Faitalpro 8FE200 + Faitalpro HF100 compression driver.
Before building I'm curious to know what is the best suitable enclosure for 8FE200.
Sealed??
Ported??
Transmission line ??
Open Baffle ???
Theoretically it is suitable for ported, based on the thumbrule of EPB=FS/QES
but seeking expert advise based on practical experience.
I can simulate sealed and ported responce in winisd etc. FS of the driver is 80 hz, so bass assistance is needed in both sealed and ported box.
But anybody used it in TL or Open baffle ????
Is there any advantage in building a TL compared to ported ???
Old 27th November 2019, 05:30 AM   #2
GM is offline GM  United States
GM's Avatar
With a 0.44 Qt and small Vas it will need a big/long vent to efficiently tune a reflex, so morph the box/vent into a MLTL or inverse tapered TQWT for better damping, maybe a bit easier build depending on its configuration.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 27th November 2019, 05:42 AM   #3
Hello GM,
Thank you so much for the inputs...
Qts=0.63
Vas= 0.48 cubic ft
Please see the attached TS parameters
Old 27th November 2019, 04:27 PM   #4
zmyrna is offline zmyrna  United Kingdom
i would say TQWT
but read this too
6fe200 + ST200
Old 27th November 2019, 06:10 PM   #5
GM's Avatar
Greets!
You're welcome!
OK, when I searched, Google gave me the 4 ohm, but only looked at the Vas, Qts spec.
Doesn't matter though, my recommendation is still the same.
GM
Old 29th November 2019, 10:29 AM   #6
please see the basic simulation graph attached.
Pink graph:
12L sealed box.
F3 = 117hz
F6 = 90hz
Green graph:
20L PORTED box.
Box tuning = 65hz
F3=64hz
F6=55hz
(there is a peak which has to be flattened further-im trying)
I know simulation doesn't exactly replicate real life performance.
I have to learn how to calculate MLTL and TQWT. I will work on it.
But meanwhile, based on your experience, what can be the advantage with MLTL or TQWT compared to sealed or ported. Any suggestion please ....
What's the best suitable enclosure for Faitalpro 8FE200Hide this!Advertise here!
Suitable Enclosure for TB W5 1611 SAF theaudiopath Full Range 35 28th March 2019 12:14 PM
Opinion on Faitalpro 8FE200-8 and SEAS CA22RNY oon_the_kid Multi-Way 6 6th May 2017 10:37 PM
Dis anyone tried FaitalPRO 8FE200 8" in an open baffle? snake69fast Multi-Way 3 6th March 2017 08:03 PM
Quickie FaitalPRO 3 vs. Aurasound NS3 in 1.8 liter sized enclosure CZ Eddie Full Range 0 22nd May 2016 05:49 PM
Suitable enclosure (or none) for E-V 12TRXB pengesluk Full Range 13 23rd July 2013 04:36 PM
Copyright ©1999-2019 diyAudio
