Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Multi-Way Conventional loudspeakers with crossovers |
The speaker I want to build has 4 binding posts connected with bridge. I understand this is made for bi amplification. However, I am never going to use that feature. Can I physically remove two of them and to wire all the wires to the remaining two?
#2 |
Speakerholic
I have moved this to Multi-Way.
Yes you can do that but the odds are you won't notice a difference removing the jumper. Personally since the posts are on the back of the speaker, and you don't see them, and if you don't notice a difference in the sound, then what have you gained?
http://www.calweldonconsulting.ca/ |
#3 |
I’m with Cal on this. Definitely don’t fall for the “upgrade” binding post snake oil scam.
Technology honors no Hippocratic oath |
#4 |
If you have metal bridges and fear that they may be deleterious to the sound, you could always make or buy jumper cables.
Personally, I doubt they would make an audible difference. You can also safely do as you suggested, but I also don't think it would be worth modifying the speaker in that way. |
#5 |
Yes. That sort of bi-amping is for those with enough imagination to think they can hear a difference.
Source: LMS 7.9.2 on FreeNAS, PiCorePlayer * Storage: FreeNAS 11 * DIY PGA2310 * Amps: 8 x LM3886TF Xover: 24dB @ 300 and 3kHz * Speakers: CNC cut 54 laminations * SB 10", SB 5", VIFA 1" * Remote: Squeeze Control |
Thread | Thread Starter | Forum | Replies | Last Post |
Dayton binding posts and binding plate | diypass | Multi-Way | 13 | 27th May 2019 08:27 PM |
What Binding posts to get? | aussiebuddha | Full Range | 19 | 10th November 2012 09:30 AM |
kef 107 binding posts | dayking79 | Multi-Way | 1 | 1st September 2008 12:47 PM |
Binding Posts | ANDYLASER | Swap Meet | 7 | 23rd November 2006 12:33 PM |
Binding posts | cp642 | Parts | 6 | 16th November 2001 03:10 PM |
New To Site? | Need Help? |
