Need very beginner help...
Old 13th November 2019, 12:48 AM   #21
DonG is offline DonG
Default A & B ?
Back on post 5 you mentioned you have A & B speakers on. Some receivers run the signal thru both speakers in series to avoid too low an impedance. So if you have only one set of speakers attached, you get no sound. Try turning off the set of speakers that you don't have connected.
Old 13th November 2019, 01:46 AM   #22
Galu is offline Galu  Scotland
Originally Posted by babz View Post
when I plug my RCA to Aux
Just to clarify, what music source are you plugging into your amplifier and with what cable?
Are you connecting a CD player to the CD input via an RCA cable for example?
Just looking for clues.
Old 13th November 2019, 02:05 AM   #23
AllenB is online now AllenB  Australia
This thread is disordered, OP feedback is inconsistent.
@Galu, why don't you make a list to check everything from the source to the speakers, and if we have anything to add we'll ask you to modify it?
Old 13th November 2019, 02:56 AM   #24
babz is offline babz
I have blamed the error on the receiver. Somebody on reddit suggested me to wire up the "wireless one" of the set of edifier 1280T's I own. The non-amp side that was not powered produced the same effects as the bose I picked up did through the receiver. Thoughts on this?
Old 13th November 2019, 03:37 AM   #25
If you mean try this powered speaker as a test around the input to your receiver, given that this doesn't use the output of the receiver, then sure. It may be looking this way.
Sorry if this adds more confusion, I was thinking about GMs comments about swapping speakers, actually running the left off the right amp etc. What you describe isn't conclusive to my mind. To those who know, running an output transistor into secondary breakdown causing permanent damage will not stop it from producing sound, it will sound quiet, but noisy, echo like.
Old 13th November 2019, 07:07 AM   #26
GM is offline GM  United States
GM's Avatar
Mine either...........
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 13th November 2019, 12:15 PM   #27
synonymous is offline synonymous  United States
Send a message via MSN to synonymous
I've tested speakers with a single AA battery before...
You can check (verify) polarity that way as well
Old 13th November 2019, 05:46 PM   #28
jReave is offline jReave  Canada
Is this a receiver that needs a jumper connection between the Pre Amp Out and the Power Amp In for the front mains to work?
The pic in post #2 has them but your pic does not.
A round about way of testing this might be to attach your speakers to the rear surrounds and then switch the surround mode to multichannel. Make sure the volume level is turned down again to start off with.
Old 13th November 2019, 05:57 PM   #29
Well spotted - babz's pre-amp section may not be linked to the power amp section!
@Babz - If the metal links (jumpers) are missing on your amp then simply link the pre-amp section to the power amp section using a short RCA lead.
And don't forget to report back!
Old 13th November 2019, 07:07 PM   #30
ferret is offline ferret  South Africa
ferret's Avatar
In fact there seems to be a jumper from Video In to Video In. Babz, check that none of the other RCA sockets have a jumper in them.
Only the Pre to Power should have jumpers
Ferret. - Gaya rules
Need very beginner help...Hide this!Advertise here!
Beginner Help. SonicLife18 Power Supplies 2 12th July 2012 12:19 AM
Beginner Amp locoo Chip Amps 7 14th October 2010 09:17 PM
Amp for a beginner eRiCdWoNg Tubes / Valves 10 24th July 2004 05:00 PM
beginner amp, 100? easyrider Chip Amps 10 20th October 2003 01:36 AM
sorry, another beginner (hopefully soon) zach Solid State 3 18th January 2002 01:48 PM
Copyright ©1999-2019 diyAudio
