Is MDF  or plywood better for speaker cabinets?
Old 12th January 2020, 12:33 PM   #191
Charles Darwin is online now Charles Darwin  United Kingdom
You can buy special bendy plywood in various thicknesses.
I've also found a plywood manufacturer where you can specify what your ply is made of including sound deadening layers which is usually used for boat building.
Never even dared to ask for prices or minimum order size though.
Old 14th January 2020, 04:38 AM   #192
tsmith1315 is offline tsmith1315  United States
tsmith1315's Avatar
Originally Posted by iamjackalope View Post
A vacuum bag will apply all the pressure you need but I'm sure you already know that.
If I'm not mistaken, 10 tons applied to a 4' x 8' sheet is a bit over 4 psi.
A friend who works at a supplier for custom marine panels brought me some leftovers, enough for two modest baffles.
5 Ply x 2 with a urethane?/cork damping layer:
Tim
Old 14th January 2020, 06:45 PM   #193
badman is offline badman  United States
badman's Avatar
That looks fantastic for our application- make a frame for the interior box and let the outside panels float (so no connection to each other, you'd see the cork layer)
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 14th January 2020, 07:34 PM   #194
tsmith1315's Avatar
That's the plan, badman- driver mounted to the outside layer of ply, and the cork layer doubles as decorative.
Tim
Old 14th January 2020, 10:52 PM   #195
badman's Avatar
If you can, I'd try to mount it to the inside and shape the wood in front- the idea being the excitation excites the inner panel and has to pass through the CLD to emit panel resonance into the room.
Is MDF  or plywood better for speaker cabinets?Hide this!Advertise here!
Cabinets made with Finland Birch Plywood Musik007 Twin Audio 161 28th February 2015 04:18 AM
Birch Plywood Cabinets made by CNC machine Musik007 Twin Audio 19 8th August 2011 08:52 AM
Anyone trid to build cabinets using bamboo plywood? G Full Range 5 14th January 2008 07:27 PM
thin curved and braced plywood for cabinets knifeinthesink Multi-Way 14 10th December 2005 10:52 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
