Don' t care for accuracy, just enjoyment, at lower volumes
Don' t care for accuracy, just enjoyment, at lower volumes Please consider donating to help us continue to serve you.
Old 9th November 2019, 02:35 PM   #1
Prolle is offline Prolle
Default Don' t care for accuracy, just enjoyment, at lower volumes
Hi all
Looking for enjoyment, nice weighty and tight bass, holographic soundstage.
Not looking for accuracy. Lower volume levels is where I listen most.
Is a proven horn or TQWT design what I should look for?
Old 9th November 2019, 06:20 PM   #2
adason is offline adason  United States
adason's Avatar
You have been member since 2013 and you found none?
Many ways to skin the cat.
Old 9th November 2019, 06:43 PM   #3
Unfortunately life keeps getting in the way
Old 9th November 2019, 06:59 PM   #4
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
If you're ok with the single driver approach, then the FHXL + Alpair A10p ticks all your boxes.
The Frugel-Horn
jeff
Old 9th November 2019, 07:17 PM   #5
jzagaja is offline jzagaja  Poland
Quad ESL57 is hard to beat especially at low levels - tonality and overall pleasure. Been using and designing horns for more than 10 years.
Visit us at http://www.diysoundgroup.com
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 9th November 2019, 07:24 PM   #6
adason's Avatar
You can certainly go that way...
But if you want great weighty tight bass you may ultimately be disappointed.
Perhaps nice little fullrangers running from 150Hz up, in small boxes easily positioned in ideal place... Plus active subwoofer with plate amp with flexibility of volume/cut off frequency/ even phase... Would be my take.
Not too expensive, flexible, waf friendly, yet potentially great sounding.
Remings me many systems i built for friends... Inspired by one old obscure sony system.
Good luck!
Old 9th November 2019, 08:27 PM   #7
Bigun is offline Bigun  Canada
Bigun's Avatar
I agree with Jeff.
The A10.3 can certainly go down low and if volumes are modest it may really be able to “do it all”. Imaging is amongst the best I have ever experienced.
I started with Pencil enclosure but recently made a smaller stand mount bass reflex for these drivers. If space is a consideration these boxes would be just the ticket.
File Type: jpg 28278692-0EDF-4F97-8D81-B34F254E7C1C.jpg (463.6 KB, 326 views)
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 9th November 2019, 08:48 PM   #8
I actually already have four Alpair 7. Bought a long time ago with intention of building Microtower Castles but again, this has to take a back seat as things in my personal and work life took over.
I am now wondering about just using one of the Alpair and building Frugel-Horns, and keeping the second pair of drivers for another project
Old 9th November 2019, 10:33 PM   #9
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
That works.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th November 2019, 10:41 PM   #10
Bigun's Avatar
I would use all four as the extra cone area might give you better bass.
Don' t care for accuracy, just enjoyment, at lower volumesHide this!Advertise here!
Does lower Qes, Qms and Qts speaker will produce lower distortion ? dipankar862 Multi-Way 110 28th May 2017 10:40 PM
Lower load resistance for lower distortion (6L6 PP) mrneedle Tubes / Valves 2 26th March 2016 04:22 PM
AR Turnable for enjoyment and tweaking smiler Analogue Source 5 30th March 2011 07:13 PM
Is a subwoofer needed for musical enjoyment?? dont argue folks(discussion) Andre Baptiste Subwoofers 52 19th March 2004 12:47 PM
OPA548 pcb layout - for your enjoyment pinkmouse Chip Amps 11 30th May 2003 03:34 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
