Don' t care for accuracy, just enjoyment, at lower volumes
Old 11th November 2019, 07:26 PM   #21
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
A FR is often limited at the extremes (some people ignore that many multi-ways have similar extension), maximum loudness levels are often limited. The fact that everything is coming from one driver can cause issues with doppler — something that is often said to be important or unimportant. Dispersion at higher frequencies is also often limited. Cone resonances/micro-resonance are required to get extension and if the cone is not well controlled there is often some FR irregularities in the top octaves.
There are ways to overcome many of these issues, and many people do not listen as loud as other’s think they should be capable of.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th November 2019, 07:53 PM   #22
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
I love to listen late at night when it's quiet and I can have the volume low, seems to me I can hear more detail then.
Old 12th November 2019, 07:03 AM   #23
AllenB is online now AllenB  Australia
AllenB's Avatar
Originally Posted by planet10 View Post
FR is often limited at the extremes ... Dispersion at higher frequencies
This has its charm, and the way it happens is acceptable.
Doppler
Is this even audible? I'd be interested in a link, with what to listen for and some kind of proof, if anyone knows of one?
Old 12th November 2019, 08:15 AM   #24
frugal-phile(tm)
planet10's Avatar
It is a heavily disputed question.
dave
Old 12th November 2019, 08:45 AM   #25
Leslie speaker - Wikipedia
Old 12th November 2019, 09:11 AM   #26
AllenB's Avatar
Lol. I've had a couple of those, cool items, 6L6 amp. George Harrison played into one on Lucy in the sky.
Old 12th November 2019, 03:19 PM   #27
celef is offline celef
Please can you list some fullrange drivers that you think has a very good value? Thank you!
Old 12th November 2019, 06:49 PM   #28
frugal-phile(tm)
planet10's Avatar
Good value, or budget priced?
I can only comment on what i have heard.
Almost any of the Mark Audios (there are a few dogs IMO), but they keep getting better at making drivers. Fostex FF85/105/165wk/FE108e∑. Initial testing suggests the 3” 16Ω Faital Pro could be really good value. Cheap is the VIFA T9G (the famed TC9 is IMO junk), SEAS FA22.
I have also heard some that are promising but that i’d like to spend more time with to evaluate their potential.
dave
Old 12th November 2019, 07:00 PM   #29
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Some swear on the titanium TBspeakers 4"
CHeck under projects at the site diBirama italian diy loudspeakers, autocostruzione, Diego Sartori
It seems that the little boxes have a dowfiring port
It's like learning sex during the Victorian era: you get to the wedding night and there are many things to do that you never imagined.
Old 12th November 2019, 09:42 PM   #30
I have some tg9 drivers as well as some 3fe22 16ohm as leftovers from a surround projects i had, can you recommend som boxes for them? Thank you!
Don' t care for accuracy, just enjoyment, at lower volumesHide this!Advertise here!
Does lower Qes, Qms and Qts speaker will produce lower distortion ? dipankar862 Multi-Way 110 28th May 2017 10:40 PM
Lower load resistance for lower distortion (6L6 PP) mrneedle Tubes / Valves 2 26th March 2016 04:22 PM
AR Turnable for enjoyment and tweaking smiler Analogue Source 5 30th March 2011 07:13 PM
Is a subwoofer needed for musical enjoyment?? dont argue folks(discussion) Andre Baptiste Subwoofers 52 19th March 2004 12:47 PM
OPA548 pcb layout - for your enjoyment pinkmouse Chip Amps 11 30th May 2003 03:34 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
