crossover design- depth of field
Old 9th November 2019, 06:47 AM   #81
AllenB is offline AllenB  Australia
Originally Posted by Robintipp
Then this happened.
Correct, putting a decade between crossover points will prevent this problem. SL showed an example with only 2 octaves separation.
This can be done with no channel cascading, no EQ and only one extra filter. Are you interested?
Old 9th November 2019, 04:26 PM   #82
Robbintip is online now Robbintip  Netherlands
Thanks Alen,
Sure am interested.
The example you posted shows both cascading and paralleling + all-pass works even when mixing them.
So I've split them up to see what could be different...
I couldn't spot them this way.
Sub: 16x Peerless XXLS P835037 (8-80Hz) awaiting Motional Feedback, Fronts: Satori WO24P-4 (80-200Hz), Satori MW16P-4 (200-1780Hz), SB26ADC (1780Hz-20kHz)
Old 9th November 2019, 04:39 PM   #83
Only when viewing the individual driver, the difference becomes apparent to me.
Old 10th November 2019, 04:26 AM   #84
Nailed it.
Only one of the lower two is correct, the one with the all-pass filters. Linkwitz has it summed up with this
Originally Posted by SL
A maximally flat response is obtained when also the 200 Hz lowpass filter phase shift in the W channel is duplicated in the SW channel by an allpass filter with the same phase response.
Just for fun, here is a version with the tweeter polarity inverted.
Old 10th November 2019, 08:38 AM   #85
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Back to the original question. My guess is simply, that the previous pair of speakers was poor, with phase issue!
A pair of stereo speakers shoud image prescisely without any "depth" illusion - unless there is some tricks done in the recording (eg. Pink Floyd). Some classical recordings may replay 3D space cues, with headphones! All of the depth we hear comes from reflections and interferences in the room!
A good test of issues with phase between a pair of speakers is to play monophonic signal, eg. pink noise of speech from radio. Image sould be sharp in the middle, but often eg. s's of speech are heard differently. This is preferably a room issue, not a fault in speakers.
It has happened several times to me and diy friends, that just one module of a pair of multiway speakers has wrong polarity, and this takes some time to hear! Then we hear depth, but in an unpleasant eery way!
Creating A Sense Of Depth In Your Mix
Radikal aktivist AINOgradient speaker project
Old 10th November 2019, 06:22 PM   #86
Some information on the early device used by Pink Floyd: Azimuth Co-ordinator - Wikipedia
About the phase issue, I experienced it too when I made a polarity error on one of the midrange. Some sounds seemed to appear coming from centre behind me. I used steep (LR8) crossover slopes in 6-way speaker so it wasn't until I measured and saw the deep nulls that I realised what was happening.
Old 10th November 2019, 09:45 PM   #87
drewan is offline drewan  United Kingdom
OK, Thanks to everyone for their input. Much of the discussions about phase was waay over my head but thanks and I'm sure it helped someone.
The whole truth and nothing but...
As previously stated built these about 3 yrs ago, and then 2 yrs tinkering with the xovers AND POSITIONING.
I finally gave into swmbo and finished the cabinets. I laminated them. To preserve the positioning I put masking tape on the floor so I KNOW they went back in the same place.
I guess this is starting to sound familiar to some...
Thats when I had the problem. The speakers were totally invisible. The sound appeared to be emanating from an invisible screen 15-18 inches in front of the speakers. I was confused to say the least.
The speakers are now about 30" from the back wall rather than the 38-40" that they were, and sound wonderful.
I'm totally stunned that laminating the cabinets could make such drastic changes in sound,
but maybe I shouldn't be really as I am well aware that just 3/4in movement in any direction of the speakers in my room is noticible.
So has the answer got to be the change in diffraction?
Steampunk is inevitable, so enjoy it
Old 10th November 2019, 10:15 PM   #88
ScottG is offline ScottG  United States
Almost all recordings have some depth to them. Reverberation is often used in mixing.
This is a good example of both with and without:
YouTube
The keyboard has some measure of depth, the vocals don't (or very close to that) - and in fact it's pretty rare for vocals on a good recording to lack some amount of depth.
I've gotten to hate this track from Rod (though even then it was never a favorite even if it is a good song), because I use it so often for image placement (..due to the way it introduces various "sources"):
YouTube
-this song along with real-time freq. response measurements showed me that fullrange driver's with "whizzer" cones were screwing up placement with added sources or "signal complexity" - typically referenced as sounding "confused" with complex material. This was almost exclusively because linearity within the "whizzer's" pass-band was constantly changing (relative to the signal or a more typical multi-way's result).
perspective is everything
Old 10th November 2019, 11:17 PM   #89
Wow haven't heard those in a long time, thanks.
YouTube
Try this as an alternative for the Rod Stewart song.
Some of these have me asking myself if they are recorded in SQ (quadraphonic) and we are trying to build speakers that are able to decode SQ by means of accoustics.
Old Today, 07:48 PM   #90
Originally Posted by AllenB View Post
Nailed it.
Playing around with VCAD is fun, but have strong doubts that the image I attached could be translated into the real world.
All LR12 slopes, IIR..
Not possible... Right?
crossover design- depth of fieldHide this!Advertise here!
Field coil driver for OB design advice sought! tommydoan84 Full Range 8 26th April 2019 01:23 PM
Zalph Audio design for near field monitors ggidzinski Multi-Way 4 6th January 2017 05:44 PM
Zalph Audio design for near field monitors ggidzinski Full Range 2 1st January 2017 07:52 PM
2 way near-field studio monitors - first speaker and first crossover makepeace Multi-Way 26 3rd May 2012 02:19 PM
JXR6 design analysis for near field setup deandob Full Range 73 13th May 2006 11:31 PM
Copyright ©1999-2019 diyAudio
