Pallet Carousel for heavy speakers?
Old 3rd November 2019, 04:41 PM   #11
DonStauffer is offline DonStauffer
Spkr Turntable.mp4 - Google Drive
Old 6th November 2019, 02:37 PM   #12
Click the image to open in full size.Progress update:
CAD design finished.
The base will be made of 2x4s, arranged so the carousel will be supported at almost all points.I'll use 3 half-sheets of 5/8" plywood: One for the centering ring and disk for the carousel, and two to make the 48" top surface double-thick for rigidity. De-sta-co makes a "straight line action" clamp that seems perfect for a "brake" to lock the platform at a particular angle. I have yet to design something like "detents" or a pin & hole arrangement to easily choose angles in 10 degree increments, but I have worked out the geometry.
The carousel delivery was delayed; I expect it tomorrow. The clamp may arrive by the weekend.
Old 9th November 2019, 02:06 AM   #13
Carousel arrived. It's well made. It does have about 1/16" of horizontal play, which wouldn't matter for its intended function, but I'm considering ways to reduce that a lot. The clamp (lock) also arrived, and looks perfect for the job. I still think this is going to be good.
Pallet Carousel for heavy speakers?Hide this!Advertise here!
Sony CDP-745 carousel canyn Digital Source 2 16th February 2018 04:29 AM
First Mid/Highs build Midbass heavy PA speakers BIGlep Multi-Way 11 19th June 2016 07:13 AM
Speakers For Heavy Metal ? What Matters ? blakkshepeaudio Multi-Way 127 24th January 2013 08:28 AM
Kodak PCD carousel has a CDM-9 laser noveltone Digital Source 0 31st October 2012 06:38 PM
Tripath and heavy loads/big speakers? Geopoliticus Class D 9 16th May 2010 02:46 PM
Copyright ©1999-2019 diyAudio
