Need Help: Designing 12" Tannoy + 15" Woof
Old 29th October 2019, 10:01 PM   #11
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
18g will likely have way too high a DCR. I never use electrilytics.
But you also have to deal with the rise in the impedance at resonance. COmpensating for that likely means many components to deal with that so that the XO has a chance of working.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th October 2019, 06:19 AM   #12
KrautNotRice is offline KrautNotRice  United States
KrautNotRice's Avatar
dave
Gotcha.
The 18ga 10.0 mh inductor has a DCR of 2 Ohms, the 15 ga version only 1.2 Ohms. But it's triple the price, putting me dangerously close to buying subwoofer plate amps to power each 15" woofer. A decent 250 - 300 Watt plate amp is around $140 + depending on sales, sometimes even lower.
Regarding the passive low-pass around 200 hz, would it be a simple 2nd order?
Can the 12" Tannoy driver be high-passed simply by virtue of being mounted in a small sealed enclosure? (I'm sure there's a technical term for that)
What kind of crossover would be needed for the drivers to be phase coherent to avoid a suck out of bass near the xo point?
The impedance correction you mention, could it be as simple as a parallel resistor, or does it have to be complicated?
If I did cross the woofer over passively, I would use an electrolytic cap as it's not in the signal path and only on a woofer playing 200 hz and down. I can't afford to be an idealist there.
If building passives costs anywhere near half as much as a pair of plate amps, it's a no brainer to go active. The plate amps would just have to have high level inputs as to not complicate setup all too much, so the only inconvenience at that point would be one power cord per tower speaker.
Thanks for your input!
Old 30th October 2019, 06:23 AM   #13
I used to have a pair of NHT SuperTwo towers, and one of the things that bothered me very much is that there was a 15 db suck out of bass near the xo point ( 115 hz or so ) between the down firing sub and the front firing mid. Certain bass notes would just be missing out of the program, I couldn't stand it. I want to avoid that.
Old 30th October 2019, 06:43 AM   #14
frugal-phile(tm)
planet10's Avatar
Originally Posted by KrautNotRice View Post
Gotcha.
Still probably too high.
...putting me dangerously close to buying subwoofer plate amps to power each 15" woofer.
Now you are starting to get it :^)
With a subwoofer amp that is pretty much how you have to do it. XO will be wherever a Q=0.707 sealed box has its F(-3).
It will probably be an RCL shunting the driver.
i donít think that anything in the XO is not in the signal path. And certainly the big cap on the Tannoy will be directly in series.
It likely is. Especially since you are not likely to get a passive right on the 1st pass.
You donít need a high level input (althou if you have a set of variable level pre-amp outs line level is preferable). The subs i have in my living room most often get hooked up with speaker wires coming off the mains terminals.
dave
Old 30th October 2019, 07:00 AM   #15
Zvu is offline Zvu  Serbia
Zvu's Avatar
You'd have to be certain that it wasn't the room or some reflection interference rather than loudspeaker. Have you measured any other loudspeaker at that same speaker and mic position ?
Tesla; George Carlin
Old 30th October 2019, 07:04 AM   #16
Originally Posted by Zvu View Post
You'd have to be certain that it wasn't the room rather than loudspeaker. Have you measured any other loudspeaker at that same speaker and mic position ?
Yes I did lots of testing and measuring at the time, and ended up removing the passive crossover and bi-amped the towers via electronic crossover (passive crossover only between mid & tweet)
Old 30th October 2019, 07:07 AM   #17
dave
Well it is settled then, either plate amps for the woofers, or build small monitors with these drivers.
In the tower with helper woofer version, how do I calculate whether or not the Tannoy driver needs to be high-passed, or if it's sufficient that it would be mounted in a small sealed enclosure? You mentioned a series cap for the Tannoy, are you saying it would have to be high-passed?
Old 30th October 2019, 07:10 AM   #18
Zvu's Avatar
I'll see what i can do about assessment of crossover components needed to cross woofer around 150Hz as soon as i get to my computer (in an hour or two). Drivers are pistonic down low so it should be quite close to actual values needed.
Why wouldn't you want to mount he woofer below the dual-concentric ? Aesthetics or some other reason ?
Old 30th October 2019, 07:14 AM   #19
Why wouldn't you want to mount he woofer below the dual-concentric ? Esthetics or some other reason ?
Thanks! It's for aesthetics, I like the clean design. Also I was thinking it might help with voices and other midrange out of the woofer not being heard if the woofer is firing down.
Old 30th October 2019, 07:14 AM   #20
Zvu's Avatar
The point is that you will not need full baffle step since there will be lots of boundary reinforcement. That means that you can get by with a woofer that doesn't have to be 4-6dB more sensitive than midrange.
Need Help: Designing 12" Tannoy + 15" WoofHide this!Advertise here!
New Faital 6" Mid-Woof 6RS140 eriksquires Multi-Way 7 29th May 2018 08:53 PM
Fostex 206 + 15" woof project 1ogic Multi-Way 0 15th January 2014 07:53 AM
8"woof with 3" xo---is this a tree i should not be barking up? osd1 Full Range 25 22nd August 2013 12:04 AM
"Small" enclosure for Tannoy 15" andersen09 Multi-Way 36 28th June 2012 07:34 PM
Best 10" woof Question apassgear Multi-Way 5 4th April 2003 09:52 PM
Copyright ©1999-2019 diyAudio
