Box port or crossover dippity do
Old 21st October 2019, 03:00 PM   #11
8ntractor is offline 8ntractor  Canada
thank you I understand. At one meter if everything below 200hz is removed the response is choppy but relatively flat. the tweeter is inverted. and the top octave still rolls off. not sure how to improve the choppiness. I measured at the listening position and included those charts also. thanks again
File Type: jpg left listening positon fr and phase.jpg (79.7 KB, 76 views)
File Type: jpg right listening position fr and phase.jpg (86.6 KB, 75 views)
Old 21st October 2019, 03:39 PM   #12
eriksquires is offline eriksquires  United States
eriksquires's Avatar
Don't worry about the chop.
Your system is pointing the wrong way. You want it to descend from around 100-200 Hz. See the B&K curve:
bruel & kjaer optimum curve For hifi - Members Albums Category - The Klipsch Audio Community
It also seems like you will need to EQ the tweeter a little to get you the last octave.
Measure the drivers individually at 1m and import into XSim. If you don't know how to measure relative speaker distance, that will be needed as well. Once there, rethink your crossover.
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Old 21st October 2019, 04:02 PM   #13
thank you eriksquires I will do that I will measure one woofer and one tweeter and enter them in xsim. thank you for the information on the optimum curve.
Old 21st October 2019, 09:12 PM   #14
here is the measurements with one woof one tweet and in x sim. I included the spl for the two speakers combined maybe I should just leave on woof disconnected.
Old 21st October 2019, 11:43 PM   #15
did you mean the drivers without the crossover?
Old 22nd October 2019, 01:00 AM   #16
ok running through xsim with the actual drivers a few small adjustments to the crossover and I think the slope is more like you showed me. what do you think?
Old 22nd October 2019, 01:09 AM   #17
AllenB is online now AllenB  Australia
I use holmimpulse to measure. You cut (gate) the result to remove the reflections. The highs come out clean and the lows become limited accordingly. This makes sense, where smoothing wouldn't.
Old 22nd October 2019, 01:48 AM   #18
thank you - I downloaded holmimpulse and will remeasure.
Old 22nd October 2019, 01:58 AM   #19
Old 22nd October 2019, 01:58 AM   #20
Yes, measure the drivers without crossovers before importing.
I think Holm will also give you the relative driver measurements, right? Make sure you set the woofer delay in Xsim so your phase matching is accurate.
Box port or crossover dippity doHide this!Advertise here!
IC: Mini Statements Drivers, Assembled Crossover, Port, Baffle oneplustwo Swap Meet 2 23rd January 2013 07:00 AM
Port lengths for 2-chamber 2-port bandpass Circlotron Subwoofers 12 15th February 2011 01:09 AM
port resonance above crossover i4gotmyid Multi-Way 1 29th November 2007 08:30 PM
Single Port Vent Better than Dual Port? Daveis Multi-Way 18 15th July 2007 06:12 AM
To port or not to port? Newbie with newly built mains starquake Multi-Way 1 18th December 2004 01:51 PM
Copyright ©1999-2019 diyAudio
