Box port or crossover dippity do
Old 12th December 2019, 10:04 PM   #171
8ntractor is offline 8ntractor  Canada
thank you -- I will get those measurements in the morning I have them with the spl meter but wuld trust the unik to be more accurate. The amp unfortunately is a Marantz 1060 as my primare is being fixed. not sure if that amp will maintain constant voltage. I do have the tweeter and woofer pair at 32" that I ran yesterday. it is some ugly gated at those levels post 165 has the same measurements with slightly different gating. I did enter them into xsim. as frd files. is the one meter critical? the room is going to get worse. I attached the xsim these are the raw drivers. thank you these are not gated the chart is gated woof and tweet 32 inch centered on tweeter no cross woof pair
Old 12th December 2019, 11:49 PM   #172
AllenB is online now AllenB  Australia
AllenB's Avatar
Originally Posted by AllenB View Post
Yes, unless you have impedance without crossover.
I meant downloaded from the manufacturers website.
Old 13th December 2019, 02:02 AM   #173
I do have the zma file from lojzek I think they are from seas.
Old 13th December 2019, 09:01 AM   #174
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
Originally Posted by 8ntractor View Post
The amp unfortunately is a Marantz 1060 ... not sure if that amp will maintain constant voltage...is the one meter critical?
If you don't touch volume controls (both amp and sound card) it should remain at a constant level, assuming wire connections are ok. 1m is just a convenient distance to capture the far field sound.
Old 13th December 2019, 02:24 PM   #175
Thank you the gated cross below is the result of the gated raw woofer and the gated raw tweeter at 32" centered on the tweeter. I have the frd files but cannot attach them.
Old 13th December 2019, 02:33 PM   #176
Lojzek's Avatar
Forum does not accept .frd extensions. Either rename to something.txt or zip the files. There is also a possibility to attach the XSim file which will pass through ok. I prefer separate files from holm.
Old 13th December 2019, 06:47 PM   #177
Thank you it loaded the txt files. I will include the orginal crossover
Old 13th December 2019, 08:11 PM   #178
here is a simple cross with the gated numbers the woofers stays the same the tweet looses all but C2 when I run this with the manufacture frd the L3 also stays to get the best fr.. Lots of speaker ripple but everything over 400 is within +/- 2db
Old 14th December 2019, 05:44 AM   #179
maybe I am over thinking this. here is a chart with and without felt gated to 400 with the current crossover so let me ask this question. if you were building these speakers what would you do at this point ?
Old 15th December 2019, 02:49 PM   #180
Lojzek's Avatar
I suggest trying to record the spl at about 1m with original crossover, drivers in phase and out of phase to observe what is going on with reverse null at xo point, gating 100 Hz. If felt makes the sound smoother, then why not.
Box port or crossover dippity doHide this!Advertise here!
IC: Mini Statements Drivers, Assembled Crossover, Port, Baffle oneplustwo Swap Meet 2 23rd January 2013 07:00 AM
Port lengths for 2-chamber 2-port bandpass Circlotron Subwoofers 12 15th February 2011 01:09 AM
port resonance above crossover i4gotmyid Multi-Way 1 29th November 2007 08:30 PM
Single Port Vent Better than Dual Port? Daveis Multi-Way 18 15th July 2007 06:12 AM
To port or not to port? Newbie with newly built mains starquake Multi-Way 1 18th December 2004 01:51 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
