Best port location?
Best port location?
Old 23rd October 2019, 12:05 PM   #41
celef is offline celef
That is the problem i think, reality works differently then a plain box simulation. Most box simulations does not take into account where i put the driver and port or where i put the internal damping material. None of the simulation softwares that i have tried have ever showed that the box tuning freq changes if i move the port ever so slightly.
No i do not believe that room gain is a fixed thing, just move any speaker around in a room and you have the answer. But that was not my first question, the question was if a down firing port makes the loudspeaker easier to position in the listening room as some mfr’s claim.
Old 23rd October 2019, 01:48 PM   #42
KaffiMann is offline KaffiMann  Norway
Fanatic
KaffiMann's Avatar
Best port location?
That is about 98.6% correct, the tuning frequency will probably not change much, but the behaviour around port resonance might change slightly, and internal modes escaping through the port will definitely change.
And the internal modes can have a profound influence on the perceived quality of the sound.
Sometimes harder, sometimes easier. Depends on the room, and the speaker.
Have you tried hornresp yet?
Things are starting to happen, work in progress: https://kaffimann.com
Old 23rd October 2019, 04:40 PM   #43
here is an example from my test box, see attachment, changes by moving the port from near floor to near midwoofer
no i have not tried hornresp, is that the only software that can simulate these effects?
Old 23rd October 2019, 04:55 PM   #44
Fanatic
KaffiMann's Avatar
Best port location?
Hornresp is relatively easy to use, it's free and still under continuous development.
For further information about various quarter wave designs, you should also go to Quarter Wavelength Loudspeaker Design
Old 23rd October 2019, 05:57 PM   #45
thanks, i will take a look at hornresp
Best port location?Hide this!Advertise here!
Port location in/on a sub 454Casull Subwoofers 11 31st January 2014 04:16 AM
zrt 2.5 port location j4richter Multi-Way 3 4th September 2013 02:06 AM
Port Location ERICSPEEd Multi-Way 4 3rd December 2008 11:50 AM
Port location andy2 Multi-Way 1 17th October 2005 11:20 PM
port location? joe_daddy Car Audio 4 18th August 2004 02:38 PM
Copyright ©1999-2019 diyAudio
