SB Acoustics Textreme.
Thread Tools
Old 17th March 2021, 07:00 PM   #761
Dreew is offline Dreew  Moldova
Buil your own speakers // Sb Acoustics evaluation room /// Munich High End 2019 - YouTube
Old 18th March 2021, 10:28 PM   #762
42476 is offline 42476
I just also ordered a new Crown power amplifier. It is model XTi 1002. LOTS of built in filter options. I looked at high quality capacitors and inductors for use with my MW13TX. I would need to spend a lot of money on passives so I decided this time; I will get more high tech with DSP, etc. The Crown is class D but if for some reason I think it doesn't do justice with the MW13TX, I can swap it out. I now (or soon will) have 5 amplifiers, not counting a D class mini amp. The first Crown I got is class A/B. It made my Satori MW and MR16s both come alive like nothing else I ever tried before.
Old 18th March 2021, 10:49 PM   #763
Deni09 is offline Deni09  Hungary
Formerly YSDR
The Crown XTi is a class A/B amp not class D. Not that it matters too much but maybe for someone.
Old 18th March 2021, 11:00 PM   #764
OK, thanks! I assumed it was class D since it can drive 2 Ohm loads. I have not read the detailed specs but the weight says it probably is class A/B; over 18 pounds. I have a XLS 2002 also and it is MUCH lighter, definitely class D.
Old 19th March 2021, 01:05 PM   #765
HiQnet Band Manager™ | Crown Audio - Professional Power Amplifiers
This thing connects to your PC via USB. MANY features so getting a custom filter will help me fine tune not only the MW13TX but I can use this amp on every driver stereo pair I have, one pair at a time, to optimize the in-room response. Now, I just need to get REW working properly; it always says I have a way lower than expected level no matter what I do or try.
Old 19th March 2021, 01:08 PM   #766
Default Crown HiQnet Screen Shot
From the online manual choices
Old 21st March 2021, 01:33 AM   #767
rhale64 is offline rhale64  United States
I can't wait for your impressions.
Old 21st March 2021, 01:42 AM   #768
Well, I am getting the amplifier so I can fine tune the FR without any passives. I realize it is WAY overkill for an amp that massive for a small, 5 inch pair but it is the features I need not the high power.
Old 29th March 2021, 04:31 AM   #769
iamjackalope is offline iamjackalope  United States
Does anyone know when the 5" drivers will be available here in the US? Is Madisound their only distributer in the US? These drivers seem to be kind of hard to obtain.
Old 29th March 2021, 04:54 AM   #770
Solen in Canada has 4 pieces coming in April; I pre-ordered 2. Madisound and Meniscus aren't showing them even as back order yet last time I checked. Call them or e mail them maybe.
SB Acoustics Textreme.Hide this!Advertise here!
Thread Tools
Raw Acoustics HT3 audioferret Multi-Way 16 30th January 2020 01:10 PM
Q acoustics 2020i vs Boston Acoustics A26 rajeshnitk Full Range 0 26th September 2016 04:43 PM
FS: SB Acoustics Kalasan (Original from SB Acoustics Factory) + Woofer modules fishball79 Swap Meet 7 18th April 2016 12:26 AM
fm acoustics ben goh Solid State 29 28th May 2012 05:49 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
