SB Acoustics Textreme.
Thread Tools
Old 23rd January 2021, 06:04 PM   #751
BPatrik is offline BPatrik
Satori MW19TX-4 | HiFiCompass
Old 26th January 2021, 06:28 PM   #752
MadtechSE is offline MadtechSE
Satori TW29TXN-B | HiFiCompass
Old 30th January 2021, 10:36 PM   #753
tktran303 is offline tktran303  Australia
Well that was a bit of anticlimax...
Better midrange but worse mid bass than the paper versions for both the MW16 and MW19.
Looks like the trade offs make it a side grade, not upgrade.
At the current prices I wouldn’t upgrade my MW13P to MW13TX...
Old 31st January 2021, 02:11 AM   #754
audiogod66 is offline audiogod66
Especially in Aus they are very expensive -not worth the price jump
Old 31st January 2021, 03:33 AM   #755
hifijim is offline hifijim  United States
hifijim's Avatar
What matters is how it compares to the competition.
Scanspeak Illuminator 18WU/4741T paper cone ~ $330
ScanSpeak Revelator 18W/4531-G00 paper cone ~ $210
SEAS Excel W16NX-003 (E0073-08) 6" Graphene Cone ~ $460
SEAS Excel W16NX-001 (E0049-04) 6" Magnesium ~ $280
Purifi Audio PTT6.5W04-01B 6.5" Woofer ~$370
The value of the MW16TX will be determined by how it compares to these other drivers, some of which cost more, some cost less...
Old 31st January 2021, 09:20 AM   #756
digitalthor is offline digitalthor  Denmark
70 vs 260$ - 5dB drop in breakup and a bit more even FR.
But is it worth it when you aim to cross around 1800hz to a waveguide?
SB Acoustics SB17NBAC35-4 Aluminum Cone Woofer - 4 ohm
SATORI 6" MW16TX-8 TeXtreme Cone Woofer - 8 ohm
I've seen the Textreme up close around 7 month ago, cause Ulrik brought it along to one of our countless hifi-gatherings.
I really dig the idea to have some mix between paper and metal, that can bring something new. Cause I always found softer cones to be a little boring - like they hide some details in the softer cone - damping. Harder cones on the other hand, needs a bit more care, but can really shine in their way of delivering an open performance - very clear and detailed.
Old 31st January 2021, 12:08 PM   #757
42476 is offline 42476
I keep going back and forth on my decision to try the MW13TX. I know for sure I will get them if the politicians give us a bigger stimulus check. Again, I would prefer a true mid or wide band "full-range" such as MR13TX over a MW version in the same size. I love my Satori MR16 mid (Papyrus cone); plenty of resolution and micro-detail and a very wide and usable band width. I read something else that because SB thinks the TexTreme mid woofers are better than the Papyrus; they may decide they won't even bother with MR versions and so we would only have MW versions to choose from. The MR16 is so much better than the MW16 at the higher (frequency) end as one would expect. The MW16P and MR16P though have to be some of the best sounding drivers in that size regardless of cost or any brand out there. They will probably always remain a great bargain when you factor in the high performance to cost ratio. I still hope SB will eventually drop the TexTreme prices after the initial models have all been released and available for all (maybe after 1 year???)
Old 17th March 2021, 06:12 PM   #758
Solen now says the MW13TX will be in stock mid April. I just did a pre-order for one pair in 4 Ohm; here we go!
Full price of course!
Old 17th March 2021, 06:49 PM   #759
nanou64000 is offline nanou64000
Nice. I hope Hificompass will test it.
Old 17th March 2021, 06:55 PM   #760
Yes, me too! Like I said many times; I would really rather have a TRUE midrange (or better yet, very wide band full range) version but that may not even happen. Some have said that SB may not do any TexTreme mids as they think the mid range performance of the MW is a good enough as is unlike with the original Papyrus cone that has separate MW and MR versions!??
SB Acoustics Textreme.Hide this!Advertise here!
Thread Tools
Raw Acoustics HT3 audioferret Multi-Way 16 30th January 2020 01:10 PM
Q acoustics 2020i vs Boston Acoustics A26 rajeshnitk Full Range 0 26th September 2016 04:43 PM
FS: SB Acoustics Kalasan (Original from SB Acoustics Factory) + Woofer modules fishball79 Swap Meet 7 18th April 2016 12:26 AM
fm acoustics ben goh Solid State 29 28th May 2012 05:49 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
