SB Acoustics Textreme.
Thread Tools
Old 20th January 2021, 10:40 AM   #741
Ugg10 is offline Ugg10  United Kingdom
Think this is the info he refers to -
SB Acoustic MW19PN & MW19TX direct comparison in the same enclosure
Old 20th January 2021, 10:53 AM   #742
Oneminde is offline Oneminde  Sweden
Oneminde's Avatar
Oh my... the paper is more well behaved.
In order to become sane in an insane world, you must first become insane.
Old 20th January 2021, 11:24 AM   #743
jcga is offline jcga  France
Originally Posted by shining31 View Post
@jcga, interesseting, did you have published something ?
Yes, it is in SB Acoustic MW19PN & MW19TX direct comparison in the same enclosure thread
Edit:
I see someone already answered you !
Old 20th January 2021, 11:45 AM   #744
tktran303 is offline tktran303  Australia
I’d say the MW9TX is better behaved, but starts to beam, (becomes more directional) at a lower frequency than the MW19P...
Old 20th January 2021, 11:54 AM   #745
Oneminde's Avatar
Look at the high frequency, beyond the cone breakup. The paper will have better THD and especially IMD compared to the TX, while the TX will have better or flatter behavior in its useful range than the paper. So while the TX fixes certain things, it apparently comes at another type of penalty - the TX require steep filters ( 24dB) and further away from the cone breakup compared to the paper cone.
Old 20th January 2021, 11:59 AM   #746
I have a 2 way speaker with the MW13P crossed at 1.8KHz.
If I were using a larger 7-7.5” mid-woofer in a 2 way, like the MW19, I’d cross below 2KHz as well. So I don’t quite see the problem between the TX or P
Old 20th January 2021, 06:14 PM   #747
hifijim is offline hifijim  United States
hifijim's Avatar
Yes, that is how I see it. Anyone who wants to run a woofer this big above 2 kHz has already decided to comprimise on dispersion and directivity. This woofer will be at its best when crossed at 2k or below, just like every other 7 inch driver.
Old 21st January 2021, 08:25 PM   #748
shining31 is offline shining31  France
Satori MW16TX-4 | HiFiCompass
Old 21st January 2021, 08:56 PM   #749
hifijim's Avatar
I really like HiFiCompass's measurements; his technique, the care he takes, the quality of his graphics and plots, his explanations.
I am pleased that my measurements in posts 542, 606, 608 agree, more or less, with HiFiCompass. It was an opportunity to embarrass myself, and thankfully that did not happen...
Old 22nd January 2021, 07:35 AM   #750
Did you notice that we have the same frequency for the first breakup mode between the 16 and the 19 version, I'm wondering why ?
SB Acoustics Textreme.Hide this!Advertise here!
Thread Tools
Raw Acoustics HT3 audioferret Multi-Way 16 30th January 2020 01:10 PM
Q acoustics 2020i vs Boston Acoustics A26 rajeshnitk Full Range 0 26th September 2016 04:43 PM
FS: SB Acoustics Kalasan (Original from SB Acoustics Factory) + Woofer modules fishball79 Swap Meet 7 18th April 2016 12:26 AM
fm acoustics ben goh Solid State 29 28th May 2012 05:49 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
