SB Acoustics Textreme.
Thread Tools
Old 18th January 2021, 06:09 PM   #731
Oneminde is offline Oneminde  Sweden
Oneminde's Avatar
animal farm isn't completely wrong. Purifi paper, Satori paper, SBA MFC, and Audio Technology PP are among the finest drivers available.
In order to become sane in an insane world, you must first become insane.
Old 18th January 2021, 10:04 PM   #732
CharlieLaub is offline CharlieLaub  United States
Originally Posted by animal farm View Post
Danes are known for being clever in business, and this is a good example, SB Acoustics teased the marked a year ahead with this textrene-secret, building expectations, rumours, excitements, forum-discussions, etc etc, and whoops, they can get away with $270 for a driver that is only "worth" around $170.
I am currently considering the MW19TX-4 for a dipole project, that is if I can ever buy one. Manufacturing and distribution seems to be delayed, but hey there is this pandemic thing going on I guess. This particular driver does seem to be overpriced by the clever Danes. Of course they are a company and not a philanthropic organization, so they want to build up the excitement and launch the product with as high a price as the market will support. This is nothing new. The question is whether the driver will perform at the very high level that we have been told to expect. If not, there are other very good drivers out there for much less coin. Time will tell.
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Old 18th January 2021, 10:18 PM   #733
454Casull is offline 454Casull  Canada
When designing a midwoofer-cone, the manufactorers look for three key characteristics: lightness, rigidity/stiffness/velocity and internal damping. They stir/heat/dry-, vacuum-, compression-, injection-mold/press multidirectionally oriented (ply-layers) of light and strong carbon/kevlar/glass/mineral/polystyrene/cellulose-fibers, mixed with some epoxy binder for shaping and stiffness, added some polymer/foam/pulp for damping, this is is how 99% of non-metal/ceramic midwoofer membranes are made, and every manufactorer has their own secret receips. Don't want to sound more grumpy than I am, but the Satori Textreme is no revolution or holy grail, it's just another thin-fiber, black-art, fancy looking membrane, one among many.
A measurement of a membrane's breakup modes, on-axis and off-axis, can tell how well damped the breakup is. The breakup behaviour does not tell how rigid the membrane is, (or what the breakup sounds like) but it can give an indication of the membrane's stiffness as well. When you look at the FR-plots of the SB Acoustics' different 6" midwoofers below, between 2-20kHz, you see that the off-axis breakup of the new MW16tx is just as bad as aluminium and ceramic, very low internal damping indeed, don't be fooled by the nicer looking on-axis response, this driver rings! The new stiff cone of the MW16tx will add some low level resolution compared to the soft papercone of the brilliant MW16P, but at a cost.
My experience with kevlar/epoxy-midwoofers, which may have lots in common with the new Satori textrene, is that for one; they need to be crossed low and steep, and two; they need really large cabinets (give them a small cabinet and some high SPL bass/lower-midrange, and they ring like hell). I never crossed a ScanSpeak 8546 or 8554 above 1400Hz, and I'm afraid that it will be the same with the MW16tx (some prefer the added "details" that echoes down from an uncontrolled breakup, but that’s another story). This might explain why SB Acoustics hasn't implemented Textrene in their Satori midrange drivers?
SB17 rohacell/carbon-fiber costs $34 more than SB17 aluminium/paper/polypropylen. MW16tx costs $114 more than MW16P, and I don't for a second belive that a textrene cone costs 3 times more to produce than a rohacell/carbonfiber-sandwich cone. In 2011 the new MW16P was $290 and the 15WU was $340. Today the MW16P is $148 and the 15WU is still $340. Danes are known for being clever in business, and this is a good example, SB Acoustics teased the marked a year ahead with this textrene-secret, building expectations, rumours, excitements, forum-discussions, etc etc, … and whoops, they can get away with $270 for a driver that is only "worth" around $170.
For midrange duties I don't like the unnatural upper-midrange sound from carbon/kevlar/glass-fiber + epoxy, I prefer Audio Technology's PP, Seas' tpx-PP, Dynaudio's PP, and Eton's Hexacone-sandwich, they all can be crossed rather high, with clean, high level detail and nice sounding breakup modes.
Thanks for the easy-to-review comparison photo.
My take on Textreme is that it's going to be a rigid cone material with a more-controlled breakup than what you'd find on a conventional rigid material like aluminum or ceramic. Seems to do the job, although I also question if there is any significant advantage vs aluminum or ceramic (as long as the application allows for adequate mitigation of the breakup), especially given the cost differential.
From a practical standpoint, SB coming out with the Textreme lineup essentially gives the end user accessibility to the wonderful Satori motor (though perhaps equalled by the NAC/NBAC series) but with a cone that doesn't suffer from surround-edge resonance and has breakup at a slightly higher frequency.
Old 18th January 2021, 10:42 PM   #734
plasnu is offline plasnu  United States
RD cost would usually be another possible reason for the higher price at the introduction of a new product.
Old 18th January 2021, 10:43 PM   #735
hifijim is offline hifijim  United States
hifijim's Avatar
You may be right... time will tell.
454Casull's thoughts match my own. My test data revealed that the Mw16TX driver has a first mode resonance that is almost as high as the SB17CAC ceramic cone, but the resonance is more damped than SB17CAC. Is this enough to make the MW16TX sound better than the SB17CAC or the MW16P? I don't know... again, time will tell.
Old 18th January 2021, 10:47 PM   #736
Oneminde's Avatar
Waiting in suspense.
Old 19th January 2021, 01:52 AM   #737
rhale64 is offline rhale64  United States
Me too. I am hoping they are game changers. If not maybe the Kairos build with the bass section would match or beat my Aerial 6t's which have Egyptian papyrus drivers for mid and woofers. These speakers are great sounding. Just wanted to build something again. But it has to beat these or it's not worth the effort. And I haven't heard many speakers at any price that I like more.
Old 19th January 2021, 03:22 AM   #738
Highly doubt it. If anything, they will just be an incremental improvement over their SOTA.
Old 20th January 2021, 09:17 AM   #739
jcga is offline jcga  France
I second that, having compared both MW19PN et MW19TX in the same application, I would say it is not a game changer
Old 20th January 2021, 09:43 AM   #740
shining31 is online now shining31  France
@jcga, interesseting, did you have published something ?
SB Acoustics Textreme.Hide this!Advertise here!
Thread Tools
Raw Acoustics HT3 audioferret Multi-Way 16 30th January 2020 01:10 PM
Q acoustics 2020i vs Boston Acoustics A26 rajeshnitk Full Range 0 26th September 2016 04:43 PM
FS: SB Acoustics Kalasan (Original from SB Acoustics Factory) + Woofer modules fishball79 Swap Meet 7 18th April 2016 12:26 AM
fm acoustics ben goh Solid State 29 28th May 2012 05:49 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
