Any ideas for a good replacement 25mm dome tweeter
Old 8th October 2019, 04:40 PM   #1
youngie is offline youngie  United Kingdom
Default Any ideas for a good replacement 25mm dome tweeter
Hi all. One off my epos k3 tweeter has popped. I am looking at replacements for it. Hopefully people can give me good alternatives for good replacement many thanks
Old 9th October 2019, 07:45 PM   #2
Dave Bullet is offline Dave Bullet  New Zealand
The cheapest option without any measuring equipment or XO design skills is to replace the tweeter like for like. contact EPOS or keep an eye out on ebay or similar for a K3 for sale.
The cabinets look proprietary / custom - so I am assuming you don't want to modify to fit another tweeter that has different faceplate dimensions.
The tweeter was probably used in other models too - so check those out. A visual might be all you need to sight which models.
Without knowing the model number, and whether a EPOS made it, or had it made to order (OEM) or "off the shelf" - we don't know what we are targeting re impedance and FR curve for a potential replacement.
It all depends on how much effort you're willing to go to.
"Usual diyaudio train wreck of dubious drivers and just the crossover to sort out. Well, how are you on crossovers and modelling? Pretty green, I reckon" - system7 (Steve)
Old 9th October 2019, 08:05 PM   #3
Galu is offline Galu  Scotland
If we are talking Epos K3 floorstanding speakers then the tweeter is described as a '25mm silk dome tweeter with short horn faceplate'.
If you have removed the tweeter, could you supply photographs, front and rear, which may identify the tweeter?
Old 9th October 2019, 08:11 PM   #4
Epos product support: http://www.epos-loudspeakers.com/sup...r-es-products/
Old 10th October 2019, 09:28 AM   #5
Zuhl is offline Zuhl  England
Zuhl's Avatar
Take it out and have a look what's underneath. Could be a normal tweeter with that horn-like faceplate added on top.
One good thing about music, when it hits you, you feel no pain - Bob Marley
Naim NDX 2 + Naim NAC72/HiCap/NAP250/NACA5
Old 10th October 2019, 04:54 PM   #6
File Type: jpg 9B0871FA-6F8E-4207-AC13-DC67AAA62E43.jpg (991.6 KB, 150 views)
Old 10th October 2019, 05:13 PM   #7
Those connections/soldering are not of the quality I would expect of this manufacturer.
Have you owned these speakers from new? Could the tweeter shown be a diy replacement? What does the tweeter in the other cabinet look like?
Old 10th October 2019, 05:36 PM   #8
Have found this interior shot of the Epos K3. Your tweeter looks like the original, but apparently has been resoldered while replacing the tweeter wiring.
Can you confirm if that is the case?
Old 10th October 2019, 05:46 PM   #9
Thanks galu yes there are the original tweeters. I brought them second hand awhile ago. I want to replace them and do a much better solider job that what you can see in the cabinets. Do you have any good suggestions for me. Once again galu thank you mate.
Old 10th October 2019, 06:10 PM   #10
Zuhl's Avatar
The only tweeter labelled 025D08 I know is the Audax TW025D08 - maybe they are based off those?
Any ideas for a good replacement 25mm dome tweeterHide this!Advertise here!
Vifa Horn Tweeter 1" 25mm Textile Dome BC25SC06-04 4 Ohm Neodymium High Efficiency HonorPC Vendor's Bazaar 0 15th February 2019 10:24 PM
Dome tweeter diaphragm replacement available? Agent13 Multi-Way 0 4th September 2018 09:26 PM
Whats the difference between a inverted dome tweeter vs a dome tweeter? DMLBES Multi-Way 24 28th March 2017 12:41 PM
Replacement dome for Audax tweeter JohnL Multi-Way 2 24th October 2007 12:00 AM
Good Peerless Tweeter Replacement? PoorSound Multi-Way 14 20th January 2006 12:44 PM
Copyright ©1999-2019 diyAudio
