You had to pay for this!? Wow...
Of course, no. A very serious seller in Italy makes measures and has a large database of the drivers he sells.
I've purchased FRD and ZMA data for my drivers. Is it better to start a new thread at this point, to have suggestions on cabinet project? Or go on here?
New thread because the purpose is now different.
IMO, the manufacturer should publish driver data (including graphs, T/S, FRD, ZMA, others) as pre-sales information so you can make an informed decision before you buy a driver.
I agree totallyNew thread because the purpose is now different.
Monacor does publish the FR and impedance graphs for these drivers, you just have to dig through their website a bit. Note that these are infinite baffle responses so you'll need a program like Jeff Bagby's Excel based Response Modeler to add in the baffle step based on cabinet dimensions and the driver location. Response Modeler will also calculate the woofer's impedance plot and frequency response when installed in the cabinet. You'll need the woofer's T/S parameters which are also on Monacor's website.
I loaded the FRD/ZMA files (provided from your new thread) into Xsim, and used your original XO component values. You can see the results are not so good.
Then I did the minimum amount of XO changes (schematic marked in red) to get a reasonable FR. There is enough LF gain for baffle step loss compensation.
There are still a lot of components in that XO that are not required for this design. They have minimal effect (ripples) so they were not removed or changed, otherwise you would be building a new XO I included the Xsim file so you can try it.
- Xover reverse engineering
