Need info on old selenium d250 compression driver
Old 17th September 2019, 06:03 PM   #1
Old Qua is offline Old Qua  Denmark
Default Need info on old selenium d250 compression driver
Hi all, I have 2 off these Selenium d250 compression drivers:
Need info on old selenium d250 compression driver-thumbnail_img_0772-2-jpg
These is not d250-x, these is not d250-trio
These are som older versions, and I would much appreciate if anybody kan give me som data on them
I got them cheap on ebay 4 or 5 years ago along with some JBL HM25-25 horns
Need info on old selenium d250 compression driver-thumbnail_img_0786-jpg
Need info on old selenium d250 compression driver-thumbnail_img_0787-jpg
I want to put them to use, but ned the info to find matching drivers so that I can built som speakers
Old 18th September 2019, 01:25 AM   #2
turboyam is offline turboyam  Canada
Hello.
I do have those specs, here they are;
Nominal impedance; 8ohms
minimum imp. @ 615hz; 7.2ohms
power handling; x-over @ 500hz, 12db-oct; 100watts music
power handling; x-over @ 1000hz, 12db-oct; 150watts music
sensitivity; (on a horn); 107db-spl @ 1 meter, on axis
frequency response @ -10db; 400 to 9000hz
RE; 6.0 ohms
flux density; 1.2 Tesla
minimum recomended x-over; 600hz
I have ALL of the specs (the actual leaflet) in hand here. If you need more. There are the usual (very accurate) graphs too...
Old 18th September 2019, 06:27 PM   #3
turboyam:
thx man :-)
The actual leaflet would be nice to have too!
I dont know how much data I really need, I am ready noob when it comes to speaker building, but I imagine that next step will be to find out about frequency responce, and polar patterns off the horn + driver, I hope to finde som software that can calculate that and think that that software might need som driverparmeters.... but as is now I don't even know if the horn alone decides the polar pattern of horn + driver or if the driver has any influens on that too.... I must find out and there after se if I can find matching drivers to make a full range speaker :-)
Old 18th September 2019, 06:49 PM   #4
LineSource is offline LineSource  United States
LineSource's Avatar
"The D250 is a cost-effective compression driver with a light-weight and strong phenolic diaphragm designed for medium band(voice) reproduction in indoor sound systems and small PA systems."
https://www.parts-express.com/pedocs...ions-44410.pdf
Need info on old selenium d250 compression driverHide this!Advertise here!
Info on the Yamaha JA-6681 compression driver Radian Multi-Way 466 20th May 2019 01:30 PM
coaxial compression driver or dome + compression? arivel Multi-Way 1 10th June 2018 03:22 PM
Wanted: One Selenium D2500Ti-Nd driver, working or not GordonW Swap Meet 0 19th November 2013 04:31 PM
I am Looking for Selenium, Radian, and BMS compression drivers Thebradly Swap Meet 0 12th April 2013 02:04 PM
Wanted: Selenium D220ti bolt-on compression drivers CZ Eddie Swap Meet 0 11th August 2011 05:32 AM
Copyright ©1999-2019 diyAudio
