Dayton Audio PA380-8 15" Pro Woofer impedance spike at 40hz
Old 16th September 2019, 02:09 AM   #1
awdtalon21 is offline awdtalon21  United States
Default Dayton Audio PA380-8 15" Pro Woofer impedance spike at 40hz
Why does this Dayton Audio PA380-8 15" Pro Woofer have an impedance spike of 300 around 40hz? When designing the crossover is there a way to get the spike down, or does it even matter?
thank you.
Old 16th September 2019, 02:22 AM   #2
Pano is offline Pano  United States
Pano's Avatar
It doesn't matter. All woofers have a peak at their Fs. Put it in a bass reflex box and you'll have two peaks.
The peak won't effect your crossover unless you are crossing very, very low. You aren't, are you?
Take the Speaker Voltage Test!
Old 16th September 2019, 07:26 PM   #3
daemonsgr is offline daemonsgr  United Kingdom
maybe read these: (`I did too as I was gathering knowledge)
The Crossover Design Cookbook Chapter 3: Speaker Motors and Crossovers
TA Speaker Topics - Neutralizing L(e) with a Zobel
Of course following what Pano said.
Old 16th September 2019, 11:23 PM   #4
GM is offline GM  United States
GM's Avatar
In which case one needs a series notch filter : Series Notch Filter Designer / Calculator
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 17th September 2019, 12:49 AM   #5
John Busch is offline John Busch  United States
John Busch's Avatar
Actually, the resonance peak is around 32 Hz. Nothing to worry about. Have purchase quite a few and they, so far, have been very consistent and very close to spec.
The peak is of little or no concern when properly used in either a vented or sealed box. Can even be used in an open baffle. How do you intend to use this driver?
Commercial Website: https://manzanita-audio.com/
Dayton Audio PA380-8 15" Pro Woofer impedance spike at 40hzHide this!Advertise here!
Dayton Audio pa380-8 new $60 bubblersound Swap Meet 1 15th March 2018 11:25 PM
Dayton Audio RS180P-4 7" Reference Paper Woofer 4 Ohm gfederys Swap Meet 0 1st November 2015 01:52 PM
Dayton Audio DS315-8 12" woofer WhiteRhino Multi-Way 6 11th June 2014 09:16 PM
Best TH for Dayton PA380 15"? mfavata Subwoofers 4 14th November 2013 08:14 PM
Dayton PA380-8 15" woofers BNIB badman Swap Meet 0 18th October 2013 11:42 PM
Copyright ©1999-2019 diyAudio
