Crossover questions
Crossover questions
Old 10th September 2019, 10:10 PM   #1
kawihornet is offline kawihornet  Canada
Default Crossover questions
Please check out the attached picture
I'm curious how the components work?
Thanks so much!
Old 10th September 2019, 10:50 PM   #2
Galu is offline Galu  Scotland
I'm curious as to the origin of this circuit.
Old 10th September 2019, 10:53 PM   #3
Draki is offline Draki  Macedonia
Deep EQ notch in the tweeter leg (possibly quite high Q, can't tell w/o values).
Old 10th September 2019, 11:15 PM   #4
Values are listed?
Old 10th September 2019, 11:16 PM   #5
Dynaudio Special 40
A guy in the Diy group drew it up for me.
Old 10th September 2019, 11:42 PM   #6
Im really curious why C3 is used?
Old 11th September 2019, 12:49 AM   #7
Dissi is offline Dissi  Switzerland
The bridge topology L2-C3 and L3-C2 actually is a passive delay network (Lattice phase equaliser - Wikipedia).
Old 11th September 2019, 11:16 AM   #8
David Morison is offline David Morison  Scotland
Originally Posted by kawihornet View Post
Values are listed?
Not the inductor values, which is what I presume Draki meant.
Old 11th September 2019, 11:27 AM   #9
YSDR is offline YSDR  Hungary
So this is a 1st order filter topology in Dynaudio's view?
It looks more like a typical 2nd/3rd order electrical -> 4th order acoustical crossover with some timing compensation, which are also supported by the measurements.
Specs:
Special Forty anniversary standmount speakers - Dynaudio
Measurements, look at the typical 2-way 4th order step response:
Dynaudio Special Forty loudspeaker Measurements | Stereophile.com
Old 11th September 2019, 09:13 PM   #10
wolf_teeth is offline wolf_teeth  United States
wolf_teeth's Avatar
The woofer has a damped 12dB electrical network (ie- coil plus zobel), and the tweeter has a 1st order electrical with ladder delay plus some padding and a tilt down via the CR filter.
The CR in front of the circuit 15uF/22 ohm lends to having a rising system impedance without it. With a CR across both the woofer and tweeter, this would not be the case, save for a lowpass induced rise or an impedance peak at Fo in lieu of the xover. Having that CR directly across the amplifier terminals should likely have a higher power resistor in tow to keep it from over heating. I would think those 2 components could be omitted as all they are doing is changing the impedance of the system. Typically an LCR is used for this purpose to suppress xover impedance humps, and far reduced bandwidth flows through the circuit if a LCR vs a CR is used.
Later,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Crossover questionsHide this!Advertise here!
MTM crossover questions SpinMonster Multi-Way 23 7th November 2016 01:59 AM
Crossover Questions & Help! jsa_ind Multi-Way 2 14th July 2012 11:17 AM
Crossover questions mrkaza Multi-Way 26 18th April 2010 10:41 PM
Crossover cap questions. Jidis Multi-Way 24 14th December 2009 11:02 PM
More crossover questions Saurav Multi-Way 50 25th April 2004 05:39 PM
Copyright ©1999-2019 diyAudio
