Speaker Build Advice Please
Old 9th September 2019, 04:15 PM   #11
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
Drivers appear worthy of using. Could not find any measurements on the yamaha, appears to be suited to a 60 litre sealed cabinet. It would make sense to perform impedance and FR measurements, otherwise guesswork. I had a chance to work on a midrange unit that looked like Saba, was a favor for a buddy and it turned out to be quite an awesome vocal performer. Vintage stuff can do quite a bit if you know how to design crossovers.
Old 11th September 2019, 12:48 AM   #12
MichaelAudFin is offline MichaelAudFin
Originally Posted by AllenB View Post
They look ok. I guess I'd start by putting them each in a box. To keep things simple, you could look at other drivers with the same sized drivers and compare box sizes.
Do you have amplifiers?
Thank you for your response..
I don't have any amplifiers, i would like to know what would be ideal for these..
Old 11th September 2019, 12:55 AM   #13
Originally Posted by knifeinthesink View Post
Whether to do this or not depend on what you want to achieve. If you want hi end sound then this is not the way to get it. If you want to build something because you like making things and think it would be cool to try, or want to learn hands one, then yes, go for it. Whatever the case without any measurement gear it will be difficult to do much. Assuming you arenít going to have what you need to measure Thiel small parameters, which you would need to design an appropriate box, I would suggest you look up cheap/easy open baffle designs. Tell us more about what your goals are and maybe youíll get some suggestions.
Thanks you for your response...
I know for sure the quality won't be the best, but I wanted to use the Yamaha for a sub and the two smaller ones for satellites if possible.
Old 11th September 2019, 03:21 AM   #14
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
Not really suitable for use as satellites. They have tiny voice coils, hence that 3 watt stamp on the back of the magnet. Put 10 watts though them full range and they might last a couple of minutes. I take it you only have one of the woofers? The cost of a capacitor to limit the high frequency getting to the Casio driver might be enough to get slightly better drivers.
I get my cheap drivers by upcycling old All-in-one home theatre sets I pick up by the road or at the tip/dump or friends who would rather buy new than repair
Something very much like those were in my very first computer speakers, driven by a 5 watt stereo chip amplifier and I managed to blow them up in a week
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 11th September 2019, 08:59 AM   #15
AllenB is offline AllenB  Australia
There are many options here, but I think almost anything will do. Something with volume/bass/treble would be useful. Old or new is good.
Speaker Build Advice PleaseHide this!Advertise here!
Need advice on what speaker to build udoitall Full Range 29 25th January 2015 12:14 AM
DIY PA speaker build - need advice please duane2012 PA Systems 16 23rd October 2012 02:08 AM
Advice on first DIY speaker build Williham Multi-Way 17 29th April 2011 09:42 PM
Advice For First Time Speaker build Kirbs252 Multi-Way 15 2nd June 2007 08:01 AM
Copyright ©1999-2019 diyAudio
