Metlako: A Small, Affordable Two-Way Unity Waveguide
Old 7th September 2019, 08:23 PM   #21
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Experimentally, I have found that the best performing midrange taps are taps that expand. The way that I get away with an expanding midrange tap is that it begins as a circle and ends up as a slit.
For instance, the entrance of this midrange tap measures 1" in diameter and it's circular. That's an area of 5.07cm^2. The exit of the midrange tap measures 4" x 1/2", for an area of 12.9cm^2.
Here's the measured polar response of the midrange array in Metlako V1
Here's the predicted response from Hornresp, which can only simulate a conventional (straight) midrange tap. (1)
Here's the predicted response from Akabak for a straight (conventional) midrange tap (red) and an expanding midrange tap (black)
Here is what I see from the sims and the measurements:
  • I believe the measured and simulated results show that the expanding taps are superior to straight taps
  • I think that some additional work on the Akabak model could be useful. For instance, the Akabak sim doesn't "catch" the null that exists at 1800Hz.
(1) if there's a way to simulate the expanding taps in Hornresp, let me know.
Old 8th September 2019, 12:08 AM   #22
I've created a GIT repo for my waveguides.
The latest version of Metlako can be downloaded here:
GitHub - crater-lake/metlako: a two way Unity waveguide
If you have a git client installed, you can get the repo like this:
johndoe@DESKTOP-FA5T5QS MINGW64 ~/Downloads/work
$ git clone https://github.com/crater-lake/metlako.git
Cloning into 'metlako'...
remote: Enumerating objects: 9, done.
remote: Counting objects: 100% (9/9), done.
remote: Compressing objects: 100% (7/7), done.
remote: Total 9 (delta 0), reused 6 (delta 0), pack-reused 0
Unpacking objects: 100% (9/9), done.
What I'd like to do is keep these online, so whenever someone is looking for the latest version, they can pull them down from git. Another nice thing about git is that I can include instructions on how to print them and build the speaker. That's the next step.
Old 8th September 2019, 06:55 AM   #23
Here's a video of Metlako V2 playing some tunes :
YouTube
Old 8th September 2019, 10:09 AM   #24
pelanj is offline pelanj  Czech Republic
That is great, thank you very much for sharing!
Old 8th September 2019, 05:25 PM   #25
Finnito123 is offline Finnito123
Thank you for sharing your development processes. What drivers are you using? Would be interested to build one myself
Old 9th September 2019, 04:48 AM   #26
lol, thought I'd listed them!
Here's the parts:
1) 2 x waveguides for a stereo pair. Get waveguides here : GitHub - crater-lake/metlako: a two way Unity waveguide
2) 1 x MiniDSP. $95, get here : miniDSP in a BOX : miniDSP 2x4
3) 4 x MCM 55-1870 midbasses. $40.68 for four, get here : https://www.newark.com/mcm-audio-sel...one/dp/39C2182
4) 1 x Tymphany NE19VTS-04. $23.10, get here : Peerless by Tymphany NE19VTS-04 3/4" Silk Dome Tweeter
Also available from Madisound.
I think the Dayton DA135 might work as a replacement for the MCM. The Dayton is 3mm too big, so if someone went this route they'd have to grind down the mounting plate to make it fit. The MCM would definitely be easier and cheaper.
Old 9th September 2019, 05:41 AM   #27
ScottG is offline ScottG  United States
-is that the new beta version?
perspective is everything
Old 9th September 2019, 02:53 PM   #28
454Casull is offline 454Casull  Canada
Great work!
Marked for later.
Old 9th September 2019, 02:54 PM   #29
What would you recommend for bass reinforcement in a nearfield setup?
Old 10th September 2019, 07:47 AM   #30
bourbon-neat is offline bourbon-neat  United States
Thanks for sharing your work and 3D printing files. If you were to buy a 3D printer now, for this type of project,
what would you buy?
Metlako: A Small, Affordable Two-Way Unity WaveguideHide this!Advertise here!
3D printed 3-way Unity waveguide home audio speaker bwaslo Multi-Way 155 28th August 2019 09:16 PM
Orthoacoustic simple two way Unity corner waveguide Circlomanen Multi-Way 13 2nd April 2019 07:42 AM
Affordable Price For Small Batch PCB Prototype & Assembly Service jackduan Vendor's Bazaar 0 22nd February 2016 01:29 PM
Unity/RBI waveguide line array go94022 Multi-Way 5 14th August 2012 04:13 PM
Small unity gain 5V output stage sought.... HankMcSpank Solid State 36 21st October 2009 09:13 AM
Copyright ©1999-2019 diyAudio
