4" or 5" Paper Midrange
Old 27th August 2019, 04:50 PM   #11
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
I recently asked a similar questions, and received many responses.
In the end, out of several choices for ~90dB/W midrange I ended choosing Monacor MSH 115.
I am happy with that choice and it sounds great, even running fullrange, naturally lacking in the bass register, but balanced and warm.
It's also a pretty cheap midrange, the only real price comparison was Faital 3FE22/25, 4FE32/35.
The Monacor MSH 115 cost me 35 GBP or thereabouts, so it fits in your budget
They may take away our lives, but they'll never take our freedom!
Old 27th August 2019, 04:55 PM   #12
diypass is offline diypass
i'll see monacor drivers....they are a possible choice, i forgotten them
Old 27th August 2019, 05:53 PM   #13
bbe22 is offline bbe22  South Africa
Faital 3FE22 (neo) is an underrated driver, I got a very good result here....
Old 27th August 2019, 05:55 PM   #14
ita flange isn't round
Old 27th August 2019, 05:59 PM   #15
yes true, I had my flanges 3d printed and it was a PITA actually.........
Old 27th August 2019, 06:38 PM   #16
GM is offline GM  United States
GM's Avatar
Originally Posted by diypass View Post
which midranga 4" or 5" do you suggest
Well, based on a ~725 Hz max - 1100 Hz min XO points where they quit being point sources, then for equal power distribution: [725*1100]^0.5 = ~893 Hz mean = 34400/pi/893 = ~12.26 cm/~4.83" effective piston diameter [not frame size] and at a ~6900 Hz max HF XO it's ~4.88 cm/1.92", so not knowing what XO's you're considering I'll let you do the math to find the size theoretically required to narrow down your choices.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 27th August 2019, 07:13 PM   #17
It's certainly overlooked. I overlooked it until recently when it was suggested. Most the Faital small drivers 3FE and 4FE look quite usable.
Neither Faital or Monacor frames are round.
For the Monacor, theres no need to recess the driver, if that is why round frames are preferable. The front frame is perhaps 1.5mm thick.
But it is small part of what put me off the Faital drivers, where flush mounting would be difficult, designed for rear panel mounting.
Monacor MSH-115 is flat stamped frame, so almost flush when surface mounted. The Faital frame looks much stronger however, and I dont know if I can make a success of rear mounting a driver yet! Though I have a few cheap drivers, with the same thick paper mounting rings.
Last edited by mondogenerator; 27th August 2019 at 07:27 PM. Reason: Correcting errors in my post
Old 27th August 2019, 09:37 PM   #18
celef is offline celef
I think the 3fe22 works fine surface mounted, so no need for routing
Visaton frs8m, however, is a real pain to mount. That driver must be rear mounted on a flange and then mounted on the speaker baffle
Old 28th August 2019, 09:27 AM   #19
guys, used as midrange driver is good ?
Old 28th August 2019, 02:03 PM   #20
sure, but as always, it depends on what your goal is
to me, a small midrange driver seems necessity to get a good system dispersion
4" or 5" Paper MidrangeHide this!Advertise here!
"Best" 5" midrange for three way 24dB active for around $80 to $140 Absconditus Multi-Way 66 23rd May 2019 09:23 AM
For sale: SEAS Prestige MCA12RC (H1304) 4.5" Coated Paper Midrange ccikk Swap Meet 4 15th June 2013 02:53 PM
Dayton PK165-8 6" Professional Kevlar/Paper Cone Midrange BHTX Multi-Way 2 12th November 2008 11:38 AM
"Vifa PL11WH09-08 Premium Line Paper cone midrange" GOWA Multi-Way 0 17th November 2007 02:22 PM
Vifa M17MH 7" paper midrange drivers JohnR Swap Meet 0 29th May 2002 02:10 AM
Copyright ©1999-2019 diyAudio
