I would like to build a protection panel for two Leak 2060. I received these speakers without a protector panel and its clothing. Which material I should choose ? Plywood, polymer or carton board? The panel will fit in an aluminum section, I will keep it in place with velcro.
Colin,
I thank you for you answer. Yes I would mean grille. Acoustically transparent, it is my concern. I fear about vibration. How much thick the plywood need to be ? I am not sure to be able to find so tiny MDF. Tygan is the cloth, I found on Ebay and on Falcon website. It seems to be more important than the structure to hold it on the speaker ?
The original grilles appear to be constructed of hardboard, probably no more than 1/8th of an inch thick.How much thick the plywood need to be ?
To avoid vibration, they need to be Velcro'd on securely.
