Open Baffle 3-way Crossoer. I need some help here
Old 15th August 2019, 06:09 PM   #1
snake69fast is offline snake69fast  Romania
Default Open Baffle 3-way Crossoer. I need some help here
Hi
I'd like to use 2 x Alpha 1A, 1 x Supravox 215s and 1 x Raal Dipole 140-15D per side in an open baffle project.
I am looking for the best crossover option.
I am open for any suggestion.
Thank you!
Old 15th August 2019, 06:41 PM   #2
adason is offline adason  United States
adason's Avatar
I would suggest bi-amplification. Optimize passive between Supravox and Raal, say from 150 Hz up. Power the Alpha's by plate amp, that gives you flexibility for crossover fr on woofers, phase and level. Use classA amp for top from 150 Hz up. Just a suggestion.
Old 15th August 2019, 09:15 PM   #3
chips666 is offline chips666  Belgium
Another suggestion,
Amp 1/ The Supravox fullrange with just a cap of 1.5uf to 2.2uf on the Raal
Amp 2/ The Alpha's crossed at 100hz til 200hz
Enjoy...
Old 16th August 2019, 09:06 AM   #4
Can you recommend a diy class A amp or a kit in the Chinese market? Thank you!
Old 16th August 2019, 03:15 PM   #5
adason's Avatar
No. Get some real stuff from diyaudio web site and build real classA amp from Nelson Pass. ACA, F5, F6, M2, Aleph J, all great sounding.
Old 17th August 2019, 11:00 AM   #6
bigdh31 is offline bigdh31  United States
I have built the ACA. It is a fairly easy project. You get everything but the solder in the kit. You end up with a darn good sounding amp. I believe it is in stock at diyaudiostore.com
Old 17th August 2019, 01:54 PM   #7
heinz1964 is offline heinz1964  Denmark
Can I ask why you use super expensive mid and tweeter and cheap (bad) woofers?
uwe
Open Baffle 3-way Crossoer. I need some help hereHide this!Advertise here!
Open baffle or no baffle for nearfield full range monitors? mdevelde Full Range 19 18th November 2016 04:26 PM
Upwards aligned open baffle? ( pop box meets open baffle ) OllBoll Full Range 3 28th March 2011 01:00 AM
Murphy baffle radios [ open baffle ] keithpeter Full Range 10 11th September 2007 07:59 PM
what effect does baffle have on open-baffle system? kappa546 Multi-Way 6 24th January 2006 10:21 PM
Australians- what solid timbers for baffle? (open baffle loudspeaker) tktran Multi-Way 13 29th November 2004 11:09 PM
Copyright ©1999-2019 diyAudio
