2.1 stereo console, need crossover advice
Old 14th August 2019, 10:31 AM   #11
nas3000 is online now nas3000  Lithuania
Originally Posted by Lojzek View Post
There is another approach to a solution in building this console. Instead of a 2.1, build a standard 2 way using midwoofer capable of outputting good midbass, namely Peerless by Tymphany SLS 3.5 inch 85s25cp04-04, for instance. Vented alignment might call for a passive radiator in case a vent could not be fitted. A simulation would help a lot.
Of course standard 2way system is always an option, but there is always a problem, that midwoofer will not play wel under 100Hz and/or at the same time will be precise in the voice range. This woofer mentioned looks like suitable from ~200 to ~4kHz. Correct me if I am wrong
Now I am looking at FaitalPro 3FE, 4FE or something from Markaudio for mid/highs or even fullrange and probably Dayton for sub.
Old 14th August 2019, 10:50 AM   #12
AllenB is offline AllenB  Australia
Originally Posted by nas3000 View Post
How it is?
You need a couple of 2 ohm resistors. Connect them to each other, this middle point goes to the woofer crossover. The two ends go to the amp positive terminals.
Old 14th August 2019, 10:53 AM   #13
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
The mentioned 3.5" midwoofer will do exactly what its TS parameters and FR offer. On the other hand, a designer can ruin or exploit its potential to the fullest extent. I have know idea what you are capable of.
Old 14th August 2019, 11:19 AM   #14
is this for dual voice coil woofer or single?
Old 14th August 2019, 11:29 AM   #15
Single. The resistors are there to allow the amps to be connected to each other.
2.1 stereo console, need crossover adviceHide this!Advertise here!
Driver replacement in console stereo Gsuth Parts 0 5th June 2017 12:55 AM
Right channel too quiet in stereo console SkyKid86 Tubes / Valves 6 22nd November 2016 05:49 PM
Making a console stereo to a speaker amp? spwath Tubes / Valves 24 26th August 2016 09:43 AM
DIY New Vintage Stereo console Hollyrock Everything Else 1 7th September 2012 07:14 AM
re-loading old console stereo bunkerbingo Construction Tips 3 18th June 2011 03:27 AM
Copyright ©1999-2019 diyAudio
