Advice for Speaker Build for Outdoor Wedding
Old 14th August 2019, 02:43 PM   #11
Pano is offline Pano  United States
Pano's Avatar
That's cool. Do you know what sort of look is out? Is it the fat, black box that she objects to?
Parts Express has some rather nice pro 10" woofers on clearance at the moment.
Take the Speaker Voltage Test!
Old 14th August 2019, 02:47 PM   #12
Pano's Avatar
FWIW there is a very large A/V company I gig for who use powered speakers on a stick every day. They are used for high end functions, meetings and weddings at fancy resorts. The solution to ugly? White Spandex covers. Simple, elegant and easy to use. I can't remember anyone ever objecting to them.
Old 14th August 2019, 02:53 PM   #13
suprstar29 is offline suprstar29  United States
I think it comes down to more width than anything. The wider it gets, the boxier the appearance, which I think is the issue. The sizing issue is more likely going to be a waveguide problem than a woofer problem. And those woofers sound like they are worth investigating!
Old 14th August 2019, 03:57 PM   #14
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
Default Perhaps worth taking into consideration?
Eminence deltalite II 2510-4, capable of playing 55Hz/-3dB in 2cuft vented, 2.5" voice coil, 250Wrms.
Eminence psd 2002-8
Eminence WG10, 70x60 deg, dictates a box width of minimum 11.6".
A crossover point in the 1.4kHz range.
Drivers+waveguides total to 490$/pair.
There is BH410 exponential horn with a more friendly 5.59" width/height.
Old 14th August 2019, 04:15 PM   #15
Pano's Avatar
Good choices.
I was thinking of these with a suitable horn/waveguide.
Celestion T5736A B-52 TF1020 10" 150 Watt Professional Woofer 8 Ohms
PRV Audio D280Ti-B 1" Titanium Horn Compression Driver 8 Ohm 2/3-Bolt
Screw on or bolt on, depending on your horn.
Old 14th August 2019, 04:26 PM   #16
Originally Posted by Pano View Post
Good choices.
That was the speaker I was just looking at and the Selenium D220Ti, but that PRV looks like a much better deal for a very similar output. I have never had experience with PRV so I didn't even consider them
Old 14th August 2019, 04:37 PM   #17
Lojzek's Avatar
Celestion and PRV are both excellent in the bang for the buck department.
Old 14th August 2019, 04:50 PM   #18
Pano's Avatar
PRV is also from Brazil. I understand there is crossover from Selenium (now JBL owned) but I don't know how much. Either will work well.
Old 14th August 2019, 05:53 PM   #19
So I have been playing with the Celestion TF1020 and the Selenium D220Ti in VituixCad and this is what I have come up with so far. How can I improve it?
Shared album - matt stojkov - Google Photos
Old 16th August 2019, 01:35 PM   #20
Pano's Avatar
To improve on that, you'll have to actually build and test it. Seems unlikely that you'd get anything that good, but certainly you've got a great start!
Advice for Speaker Build for Outdoor WeddingHide this!Advertise here!
Advice on first bluetooth speaker build hmsdexter Class D 0 24th September 2018 06:00 PM
Need advice on what speaker to build udoitall Full Range 29 25th January 2015 12:14 AM
DIY PA speaker build - need advice please duane2012 PA Systems 16 23rd October 2012 02:08 AM
Advice on first DIY speaker build Williham Multi-Way 17 29th April 2011 09:42 PM
Copyright ©1999-2019 diyAudio
