Peerless by Tymphany 830668 10"
Old 12th August 2019, 12:19 AM   #11
Moondog55 is online now Moondog55  Australia
Moondog55's Avatar
I think you want something that single woofers won't give you but if you have four of these small boxes then using a pair of them up to 300/350 [ I personally would cross much lower than that tho] and one of the pair set to cut-off at about 80 for low end boost should work. Once the top boxes move out of their pistonic range you have no problems with distortion or power handling up to the thermal limits, especially if the top boxes are sealed as they should be for best integration
The Peerless woofer is rated 70 watts RMS, I doubt if even I would be listening to that woofer played that loud for long. Personal opinion only but deep bass and punch are two very different things and need different drivers. Why no use a pair of each? The Peerless to about 120/200 possible 300Hz and the Dayton below 80 with wide [ low "Q"] boost at 30 Given subwoofer placement and room gain as part of the solution
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 12th August 2019, 12:21 AM   #12
PeteMcK is offline PeteMcK
Re" if I put them in 1cuft sealed boxes. Are they capable of producing in the 20-30hz area"
- no , they need about twice that volume, and need to be vented
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 12th August 2019, 12:14 PM   #13
CharlieLaub is offline CharlieLaub  United States
Hmmm, I would definitely NOT suggest a vented alignment for the 830668. The Qts is rather high. MFG spec is Qts=0.55. That's too high for vented, and you would need a HUGE box.
The 830668 is an "old school" woofer that is best used in a large box, not in a small box with a boost at low frequencies.
One 10" sub that could works well for you in 1cuft is the Dayton RS265HO-4. This driver is a true modern subwoofer designed for small volume sealed enclosures. You will still need some boost of about 3-6dB around 25-30Hz to extend the response and in 1cuft it can handle 200W or so before reaching Xmax (that's per driver, for two of them you will need two 200W channels). Do not parallel the drivers, because they are already a low 4R load, each. I would get two 200W class plate amps and use one per driver.
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Old 12th August 2019, 12:57 PM   #14
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Peerless XLS-10 should be considered too. It is designed for BR but with dsp it should work as sealed too, Much lower VAS and higher Le. Dayton RS265 might be even better.
Radikal aktivist AINOgradient speaker project
Old 12th August 2019, 03:19 PM   #15
chris661 is offline chris661  United Kingdom
chris661's Avatar
Originally Posted by 10000 hz legend View Post
Iím no expert, but it sounds like Moondog was pointing out that the amount of watts needed to max out the excursion on the peerless 830668 in a 1ft sealed enclosure exceeds the watts that it is capable of handling. Is this right? In other words the amount of air pressure in a 1ft enclosure is just too much for this particular woofer? Again, I will have four of these subwoofers so even if that is true I donít think that it be a problem for me because I donít see myself ever needing all four of these subwoofers at full xmax at 20-30hz. I could be wrong about that, but it seems like that would be pretty loud.
The thing to remember is that excursion is a peak, while the thermal power handling of these drivers is measured over a few hours.
I've dropped 500w+ into some Tang Band W6-1139s, but they were only receiving those power levels for a small fraction of a second - not long enough to cause much heating.
I honestly think you'll be fine with these drivers and a few hundred watts per driver.
Chris
My work: www.grimshawaudio.com
Old 12th August 2019, 08:32 PM   #16
ScottG is offline ScottG  United States
-he is looking for something at about half that cost. (..I was originally thinking about the Visaton 250XS when factoring-in use into the midrange.)
Dayton Designer Series ALUMINUM:
Dayton Audio DSA270-8 10" Designer Series Aluminum Cone Woofer
https://www.parts-express.com/pedocs...ifications.pdf
-of course this driver ideally wants about 3 cubic feet, so the "high-pass" behavior on the low end is going to start higher in freq. and not have as much output as low in freq.. Unfortunately linear excursion is modest (for low freq. "boost").
perspective is everything
Old 12th August 2019, 09:13 PM   #17
Moondog55's Avatar
And yet people report back that it works well in Paul Carmodys Tarkus; but it uses a big box in that speaker.
Old 12th August 2019, 10:26 PM   #18
10000 hz legend is offline 10000 hz legend  United States
Thanks for the input guys.
I am not completely opposed to spending more money. Charlielaub suggested the Dayton Reference. If I went with something other than the Peerless 830668 I was looking more so at the Dayton RSS265HF-8 because it is 8ohms. I donít know if this will give me the same or similar results as the 4ohm HO version, but I went this route I would simply buy a more powerful pro amp like the QSC GX3 or GX5.
The beefier daytons will obviously perform better in the low end in these small sealed cabinets, but will they do well in the higher frequencies like 250-500?
I also have considered the Dayton Designer series which seems to sit in between the Peerless and the Dayton Reference HO and HF.
Old 12th August 2019, 10:49 PM   #19
I think this really depends then on what you want from the result.
If you want to have very low freq. output near the average and are willing to eq. the design, then spend more money on the higher excursion driver with dual-wound VC.
If you want something that sounds more "dynamic" (upper-bass) but doesn't extend as low in freq. near the average, then go with the DSA 270-8 (..which is 8 ohms). Its MUCH more efficient, but only has about a 3rd of the linear excursion. Distortion will be lower above 60 Hz for it, but much higher below 50 Hz when compared to the RSS265HF-8.
If you want both qualities:
TIW 250 XS - 8 Ohm Visaton | Mouser
Old 13th August 2019, 02:43 AM   #20
dwk123 is offline dwk123
I'm actually starting on a similar project, also using the SHD. Initially, I'll be using the NHT Xd monitor tops w/ passive xover on top of the woofers, but will eventually rebuild these drivers into a more dramatic cabined.
IMHO the Dayton RSS drivers are ideal for this. I'm still deciding between 2xRSS210-HF per side sealed vs 1x RSS265HO ported. Both of these scenarios do very very well in 2 cu ft (or less for the 265), although the 210's ideally require 4 amp channels vs 2 due to the 4 ohm load (I'd use 2 3e-audio 3255 boards in that case).
I've run the Xd tops with 1xRSS210HF with high quality signal/amplification, and IMHO the results are very satisfying.
Peerless by Tymphany 830668 10&quot;Hide this!Advertise here!
Peerless by Tymphany 3" Enclosure Recommendations singhboyuk Full Range 5 20th March 2019 02:02 AM
Peerless Tymphany 4" sub with passive radiator f0rmula Subwoofers 4 23rd May 2018 08:06 AM
FS: Peerless SLS 10" Subwoofers, Pair, 830668 matevana Swap Meet 3 16th July 2014 04:43 PM
Peerless 830668 10"s bi-amped music only system mikemarion Subwoofers 23 25th November 2012 05:48 AM
Peerless 850146 "replacement" 830668 fat_terry Multi-Way 13 24th January 2007 03:03 AM
Copyright ©1999-2019 diyAudio
