help with crossovers and impedance
Old 9th August 2019, 01:04 AM   #1
Trevinni87 is offline Trevinni87
Default help with crossovers and impedance
if im setting up a center channel speaker using 4 speakers. 2 woofer, 2 tweeter, and crossover. if my reciever is looking for an 8 ohm load what ohm rating should i get each speaker to end up with the desired 8ohm load? and if it isnt too much trouble could you explain how it ends up there? i understand the math behind just the speakers and wiring them either series or parallel or a combo of the two but i get really confused once you add the crossover.
from what i understand when you add the crossover it takes on the ohm load rating of the woofer channel? so if the woofer channel is 8ohms and the tweeter channel is 4ohms then the reciever sees the whole thing as 8ohms but i feel like i misunderstood that.
any help would be awesome thank you so much guys.
Old 9th August 2019, 02:40 AM   #2
rayma is offline rayma  United States
You'd have to use two 4 ohm drivers in series to get 8 ohms. Two series 4 ohm woofers result in an 8 ohm load in the bass. Two series 4 ohm tweeters result in 8 ohm load in the treble. The crossover electrically blends these two 8 ohm loads so that the load presented to the amplifier is 8 ohms through the entire frequency range.
The woofer crossover lets the amp see the 8 ohm woofers in the bass range, but it unloads the amp in the treble. The tweeter crossover lets the amp see the 8 ohm tweeters in the treble range, but it unloads the amp in the bass. These two crossover sections are in parallel, so when one section unloads the amp, the other section loads the amp. This results in the amp being loaded with 8 ohms in the entire range.
Old 9th August 2019, 03:00 AM   #3
wow excellent answer that is exactly what i was looking for. thank you so much.
Old 9th August 2019, 07:45 AM   #4
jareksy13 is offline jareksy13  Poland
Default Help for JM Lab crossover repair
Hello,
Asking for help.
Can anybody send me actual schematic for JM Lab Olymp K2 loudspeakers' crossover?
I have bought the pair spekers and I found the sound of the them to be very strange. So I unscrew the mid-bass speaker to have a look at the crossover and found it to be in very poor condition (see the picture).
I can repair the PCB but must have the original schematic for the crossover to reconstruct it.
Thank in advance for your effords,
Jarek
Old 9th August 2019, 05:38 PM   #5
buggers is offline buggers  United States
buggers's Avatar
Using 2 tweeters is a bad idea sound wise...
Old 9th August 2019, 05:53 PM   #6
Galu is offline Galu  Scotland
If so, a positive suggestion would be to use one 8Ω tweeter instead of two 4Ω ones.
P.S. +1 for rayma's excellent answer.
Old 9th August 2019, 06:12 PM   #7
The physical condition looks OK to me, just a bit messy because of the hot glue applied to hold components in place.
The only components worthy of changing would be the non-polar electrolytic capacitors (the cylindrical ones). You will find the required values written on these capacitors.
What's written on the big grey cylindrical thingy?
Old 9th August 2019, 06:28 PM   #8
Hi again Jarek!
I can't locate a circuit diagram or even an alternative photo of your crossover
It is possible that the previous owner has modified the crossover and that may explain the untidy hot melt glue.
That's why I am interested in discovering more about the grey cylinder which looks out of place to me.
Old 9th August 2019, 06:36 PM   #9
Hello Galu,
I have the photo of original crossover (unfortunately I cant read the lettering on some elements) which certainy differs in many details from existing one:
1. No big inductance in bass section. Was replaced by capacitor.
2. No third power resistor on the PCB. Empty drilled holes.
3. Original PCB has some gaps grinded in few places. Have some extra winding jumpers too.
4. Big grey cap is a 40uF/450V one. They are using such components in fridges to start asynchronous motors.
My conclusion is the tweading job was done by a bungler.
Thanks for the answer,
Jarek
PS. Photo of original crossover can be seen on French internet webside.
Old 9th August 2019, 07:33 PM   #10
Thanks Jarek!
Yes, as I finally suspected, modified by a bungler!
I now see why you require the crossover schematic so urgently!
Sorry I can't be of further assistance - would be interested in having the link to that french website though.
help with crossovers and impedanceHide this!Advertise here!
Transformer for driving high impedance headphones from a low impedance source? pixpop Headphone Systems 2 30th July 2019 09:21 AM
Impedance and Passive Crossovers BassDoctor Multi-Way 18 20th March 2014 10:42 PM
Questions regarding electronic crossovers, bi-amping and impedance equalization Rodeodave Multi-Way 27 23rd January 2013 02:57 PM
Impedance compensation in crossovers EspenE Multi-Way 6 11th January 2007 07:05 PM
Impedance and Crossovers? 8ohm or 1000ohm - I'm confused! Ovation Multi-Way 32 6th August 2004 12:15 PM
Copyright ©1999-2019 diyAudio
