Why is floor bounce considered only a bass issue?
Old 7th August 2019, 07:35 AM   #21
system7 is offline system7  United Kingdom
system7's Avatar
As I mentioned, floor bounce, which is better described as the "Allison Effect", is a very interesting suckout in a loudspeakers performance which leads you on to considering the whole loudspeaker/room interaction.
If you do your homework, which is not what the Lazy Student does, you reach this impressive understanding of the effect of the floor on the bass performance from Roy Allison:
Originally Posted by Roy Allison
Lander: You hold a patent relating to this boundary-effects phenomenon. What does it cover?
Allison: The design of cabinets that get the woofer very close to one or more adjacent room surfaces. That changes the frequency range of the dip, because the closer the woofer is to a surface or to the point where surfaces intersect, the higher in frequency the dip occurs. In the case of a three-way system, it's possible to position the woofer so the dip is above its operating range, and to place the midrange driver far enough away from an intersection for the dip to occur below its range. In effect, that eliminates the problem.
A Glorious Time: AR's Edgar Villchur and Roy Allison Allison Part 2 | Stereophile.com
All this THEORETICAL STUFF is all well and good, but "WHAT DOES IT MEAN IN PRACTICE?"
Stuff like this, which is the wall mounted Acoustic Research MST:
Aspects of the design I like there... especially those cone tweeters.
Or a much more expensive design we just saw:
One of my heroes in this forum, Joachim Gerhard, also got interested in floor bounce, He got to this:
The Quintessentially German Loudspeaker of the 70th. Modern Interpretation.
TBH, I don't want to get into MTM or MTTM lobing and combing. You either get it about dispersion or you don't. The inverse square law of power at heart. Where we get to, IMO, is the room greatly influences the loudspeaker's sound. For sure, a bit of damping like carpet and rockwool on the walls clears up the midrange clutter. The bass is more difficult. For that you need to know about wall-mounting and floor bounce.
Best Regards from Steve in Portsmouth, UK.
Old 7th August 2019, 08:10 AM   #22
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
Was reading up on this not long ago- floor bounce, floor gain etc
Not sure if it was Jeff Bagby, but one well known designer suggested not putting a bass driver too far down- ie bottom of baffle. Cant remember the reason.
Magico need floor gain to boost the system sensitivity of their sealed drivers, sometimes these are relatively small in diameter. Because of the gap to the mid, Magico usually have a mid only.slightly smaller, I guess for good reproduction of male vocals.
Old 7th August 2019, 04:38 PM   #23
phivates is offline phivates  United States
Hey Steve thanks for the reminder about Roy Allison. Of course that was back before science was incorporated into speaker design...
I might have enough AR 4 tweeters to do that MST. No, not CTS phenolic ring jobs, AR. Gosh!
Old 7th August 2019, 06:16 PM   #24
norman bates is online now norman bates  United States
norman bates's Avatar
I've been tempted to add another 12" to my 12" 2-way (28" tall) that sits on the floor now.
I like what I have, just trying to get closer to the midbass that my double 15's had, even at low volumes.
Usually when I lift speakers off the floor, i lose bass, so adding another woofer under it (like a midbass module), may not help me get more bass than what I have.
I like a deep impact-full 2 way with 1 crossover up at 1,200hz.
I got sensitive to crossover in bass region I guess from years of double 15 crossed at 750hz........
Any thoughts / opinions ?
Old 8th August 2019, 10:25 AM   #25
Defo is offline Defo  Norway
How does speaker/baffle tilting affect floor bounce frequency?
I wonder if tilting the midrange upwards would allow it to be placed closer to the woofer while still keeping the floor bounce frequency the same.
Old 8th August 2019, 12:29 PM   #26
AllenB is offline AllenB  Australia
If it's in the same location the frequency will be the same. The angle may affect the level of the reflection.
Old 8th August 2019, 07:59 PM   #27
Dave Bullet is offline Dave Bullet  New Zealand
If you can measure - try the woofer at various heights. If your already have close floor placement, then use bricks / blocks. If too high - put the enclosure on its side and do the same. My placement was largely due to aesthetics and to keep the woofer above "foot kicking" distance - since there are no grilles, such that a clumsy walker doesn't boot it in!
"Usual diyaudio train wreck of dubious drivers and just the crossover to sort out. Well, how are you on crossovers and modelling? Pretty green, I reckon" - system7 (Steve)
Old 10th August 2019, 11:07 PM   #28
Doing simulations, I still can't get how Gradient can get away with a downfiring woofer...
With normal listening distances between 2,5 and 3,5 meters the floor bounce ends up being around ~300 Hz. Which means the woofer needs to be crossed at about 500 Hz to cover the dip somewhat properly. But they cross at 250 Hz
Old 11th August 2019, 05:45 AM   #29
GM is offline GM  United States
GM's Avatar
Since you have 12", two = a 'fat' 15", so [4] 'on the floor' to match/best the dual 15" 'on the floor', though of course means a new, wider cab.
Right, you lose the floor's mirror image and even if on the floor it's much reduced at > 3x driver radius, so the closer to the floor the better the mirror image and of course it must be perpendicular and setting on a massive, etc., no carpet, etc., floor for max efficiency, though even my carpeted 'floating' floor does fine, though they calculate in the 300+ lb/ea., so maybe just having really heavy speakers is sufficient.
If near a wall or corner all these 2pi guidelines can get really blurry, so strictly a worst case scenario so may can get by with dual 12", optimized room placement.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 11th August 2019, 09:37 AM   #30
iamjackalope is offline iamjackalope  United States
Can't this be fixed with an EQ or DSP?
Why is floor bounce considered only a bass issue?Hide this!Advertise here!
Woofer placement and floor bounce sfdoddsy Multi-Way 1 9th October 2015 02:49 PM
Audibility of floor bounce? mlee Multi-Way 15 4th September 2014 03:48 PM
How to calculate floor bounce reflection(cancellation) jtsaudio Multi-Way 16 7th August 2014 08:47 PM
Floor coupling issue (I supose...) andruca Multi-Way 0 11th January 2007 06:58 AM
HOw close does driver need to be to floor to avoid floor bounce? Kanga Multi-Way 8 24th April 2003 06:09 AM
Copyright ©1999-2019 diyAudio
