Kit Decisions From Troels
Old 1st August 2019, 04:00 AM   #1
jf4828 is offline jf4828
Default Kit Decisions From Troels
Iím going back and forth trying to decide if I want to build Ellipticor-4 or ďThe LoudspeakerĒ from Troels Gravesen as my new reference replacing Linkwitz LX521. While I love the LX521s I have an itch to build something new because building is part of the fun for me. Iíd also like to get into building amps and 2 amp channels seems much more manageable for something like the Pass labs kits. I realize very few on this forum have heard either, and even fewer both. I have a whole basement to myself so size and looks arenít a factor, I care about sound quality, dynamics and imaging most. I typically listen at < 90dB about 8 feet away.
Iíve designed and built many loudspeakers so complexity doesnít intimidate me. I do have a full suite of measurement and design tools... Just looking for some arguments on what others would prefer and why. Iíd like to stick with Troels stuff because Iíve leveraged many of his ideas and used some of his designs as starting points for my own with great success.
Old 1st August 2019, 05:05 AM   #2
Bill Coltrane is offline Bill Coltrane  Netherlands
I would go for the loudspeaker, but without the hypertweeter, just eq the compression driver and horn to be flat. SKip the silly prized crossover components or even better go active with dsp.
Then change the case to have minimal diffraction.
Also I would make sure that the of axis response is smooth.
This kind of design is proven to have high preference in double blind listening tests. But that's me.
Subjective measurements with the proper protocol is the only thing that matters.
Old 1st August 2019, 05:14 AM   #3
Zvu is offline Zvu  Serbia
Zvu's Avatar
What Bill said.
Tesla
Old 1st August 2019, 05:57 AM   #4
Yeah, “The Loudspeaker” was my first instinct. In LX521s I used both miniDSP and ASP.4 and found the analog processor significantly better; especially WRT soundstage. What’s a good DSP in current market that handles 2 in 8 out besides miniDSP? I’m not against DSP I just think the A/D and D/A is important. I use RME ADI-2 for DAC and some equalization and it does a fantastic job. With LX521, the DACs built into my AVM60 sound good but the RME sounds clearly better to my ears.
In Playing with my own designs, I can’t really distinguish cheap from more expensive poly caps so I’m with you there!
Old 1st August 2019, 07:00 AM   #5
Ugg10 is offline Ugg10  United Kingdom
If your source is digital then you could use the minidsp nanodigi with four DACs to provide the 2x8 dsp solution. I looked at this using 4 khadas tone boards which measure really well especially with the coax spdif input and for £80 each does not break the bank. But you can use any four DACs or possibly a lucid 88192 (you may need to look into coax spdif to aes conversion) or buy another three RME’s.
Just a couple of ideas.
Old 1st August 2019, 07:06 AM   #6
fatmarley is offline fatmarley  England
Originally Posted by Zvu View Post
What Bill said.
+1
Old 1st August 2019, 10:07 AM   #7
LineSource is offline LineSource  United States
LineSource's Avatar
What Bill said... Use the 3-main(W-M-T) drivers Troels selected for "the Loudspeaker" in a new low edge-diffraction cabinet with active Xovers.
"I would go for the loudspeaker, but without the hypertweeter, just eq the compression driver and horn to be flat. Skip the silly prized crossover components or even better go active with dsp. Then change the case to have minimal diffraction." - Bill Coltrane
Somewhere, over the RainBow.... Coaxial compression drivers like the new B&C DCX464 are being customer tested on waveguides/horns.
Before you decide to build a large speaker like Troels "the Loudspeaker", it seems worthwhile to study a few BMS 4594HE coaxial compression driver designs, and wait until a few B&C DCX464 designs are tested.
Should the midrange be a speaker like the 18Sound 10NMBA520 covering 200Hz - 1300Hz -OR- a coaxial horn like the B&C DCX464 which covers 400Hz - 19,000Hz?
If you decide to build Troels "the Loudspeaker" consider external DSP + amps for both wider hardware options, and easy future re-use on new builds.
Plate amps are forever.... putting a fan inside your speaker sounds like the punch line of a joke.
The 36" wide LeCleach eJMLC300 looks like the perfect basement horn.
Old 1st August 2019, 10:38 AM   #8
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
I don't understand how anyone commit this much on a kit with out knowing if they like it it? Is this a clone of a known great speaker and should sound amazing?
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert
Old 1st August 2019, 01:47 PM   #9
Now why did you have to go and show me those coax drivers? Looks like B&c will change the market if these things test well.... Maybe I’ll wait for the dust to settle...
Old 1st August 2019, 06:39 PM   #10
LineSource's Avatar
jf4828, Maybe.... Find / sketch 3 possible designs which will work well in your listening room to research. Plan 2 future Left + Right stereo subwoofers.
1) Troels selected 3-main(W-M-T) "Loudspeaker" drivers a new low edge-diffraction cabinet with active Xovers. Experiment on cutting 2" - 3" radius quarter rounds on top, left, right baffle edges .
2) Coaxial compression driver in a plastic horn SEOS24, SEOS30, eJMLC300, plus a woofer box.
3) Coaxial compression driver in a home-made SYNERGY horn with added woofer ports to cover down to 100Hz.
The BIG Question:
Should the midrange be a driver like the 18Sound 10NMBA520 covering 200Hz - 1300Hz?
-OR- a coaxial B&C DCX464 on a controlled directivity horn which covers 400Hz - 19,000Hz?
-OR- a coaxial CD in a Synergy-Horn which adds ported woofers for controlled directivity 100-19,000Hz?
100Hz two-way synergy project
Kit Decisions From TroelsHide this!Advertise here!
Aikido PSU decisions bloozestringer Tubes / Valves 4 21st June 2015 08:52 PM
Output Transformers... Decisions Decisions RTF671 Tubes / Valves 10 27th February 2011 12:42 PM
SEDHT amp - decisions decisions mobyd Tubes / Valves 1 21st August 2010 03:13 AM
sub decisions v1d9uy Subwoofers 3 30th July 2006 02:54 PM
Decisions, Decisions - Help me select iron kstylianos Tubes / Valves 7 14th February 2006 12:05 AM
Copyright ©1999-2019 diyAudio
