Big Two-Way Horn System for Mono?
Small world: I live in souf' Austin and my folks used to live in Cibolo.
Something like you're using: horn/bass bin 2-way (1505s, though, wow!) or something in the corner is what I'm gravitating to now.
A friend just gave me a spare Edcor stereo to mono coupling transformer, so now I just need to buy an Ortofon 78 cartridge, which apparently will work fine with my Ortofon 2M Black (Shibata) stylus. I have a ton of mono classical records I acquired a few years ago and haven't heard yet.
Nice, I grew up in South Austin, moved down here to San Marcos a number of years ago.
Sounds like you're getting the source gear together for certain!
FWIW, historically, deep bass is < ~60 Hz and depending on whose chart you use, 135 Hz is either just bass, mid bass or upper bass. :headbash:
Up until a decade or so ago, live prosound's 'deep' bass peaked at 80 Hz and fully -24 dB/40 Hz and I imagine still more the rule than the exception at large outdoor concerts.
GM
After realising that 90% of my listening if of pre-1930's recordings I made up this - which gives lots of pleasure!
142hz hybrid-horn with Axi2050 and a sealed bass 18FH500.
The horn driven by a 300b amp with Nickel OPT and is loaded from 200hz and is pretty flat to about 15khz. I use a WARM tube EQ and adjust freely for each recording. The bass is driven by a Behringer NX3000D which adds the delay to meet the treble horn.
This also functions as a centre speaker in a 3 way stereo system.
  • Thank You
Reactions: 1 user
That's a great horn system. I've heard wonderful things about the Axi2050 driver. How do you like it?
Well, it's going to take a while to explore what it's capable of - there aren't not many drivers around that can go as low. My hunch is that the 200-800 range is really fantastic. But I'll need to try them on different horns etc.
There are very few that I know of certainly. I'm excited to hear your thoughts on the Axi250, I didn't even realize it was publicly available.
Gable
That is a very beautiful hornspeaker. In my limited experience of building horns, the bigger the better. Even in mono they can sound very three dimensional. I have found that not pushing them too much with excessive eq gives a sound which is less tireless on the ear.
tapestryofsound
