Big Two-Way Horn System for Mono?
Old 26th July 2019, 06:46 PM   #21
soldersmoker is offline soldersmoker  United States
BTW, I've also contacted John Inslow about possibly buying his plans for the DIY tapped horn sub. That might be a lot of fun.
Old 26th July 2019, 06:51 PM   #22
pcgab is offline pcgab  United States
Originally Posted by soldersmoker View Post
Small world: I live in souf' Austin and my folks used to live in Cibolo.
Something like you're using: horn/bass bin 2-way (1505s, though, wow!) or something in the corner is what I'm gravitating to now.
A friend just gave me a spare Edcor stereo to mono coupling transformer, so now I just need to buy an Ortofon 78 cartridge, which apparently will work fine with my Ortofon 2M Black (Shibata) stylus. I have a ton of mono classical records I acquired a few years ago and haven't heard yet.
Nice, I grew up in South Austin, moved down here to San Marcos a number of years ago.
Sounds like you're getting the source gear together for certain!
Old 26th July 2019, 07:00 PM   #23
I have a pair of his 135hZ mid-bass horns that I built a few years ago. They're fantastic horns, and John is a great guy.
Old 27th July 2019, 12:10 PM   #24
I just sprang for his plans. It seems like a fairly simple way to get deep bass fairly unobtrusively. I've always wanted to hear tapped horns. Now I'll want those mid-bass horns . . .
Last edited by soldersmoker; 27th July 2019 at 12:11 PM. Reason: spring sprang sprung
Old 27th July 2019, 03:07 PM   #25
GM is offline GM  United States
GM's Avatar
FWIW, historically, deep [sub] bass is < ~60 Hz and depending on whose chart you use, 135 Hz is either just bass, mid bass or upper bass.
Up until a decade or so ago, live prosound's 'deep' bass peaked at 80 Hz and fully -24 dB/40 Hz and I imagine still more the rule than the exception at large outdoor concerts.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 28th July 2019, 11:13 PM   #26
maravedis is offline maravedis  United Kingdom
After realising that 90% of my listening if of pre-1930's recordings I made up this - which gives lots of pleasure!
142hz hybrid-horn with Axi2050 and a sealed bass 18FH500.
The horn driven by a 300b amp with Nickel OPT and is loaded from 200hz and is pretty flat to about 15khz. I use a WARM tube EQ and adjust freely for each recording. The bass is driven by a Behringer NX3000D which adds the delay to meet the treble horn.
This also functions as a centre speaker in a 3 way stereo system.
Old 28th July 2019, 11:58 PM   #27
That's a great horn system. I've heard wonderful things about the Axi2050 driver. How do you like it?
Old 29th July 2019, 11:18 PM   #28
Well, it's going to take a while to explore what it's capable of - there aren't not many drivers around that can go as low. My hunch is that the 200-800 range is really fantastic. But I'll need to try them on different horns etc.
Old 30th July 2019, 12:38 AM   #29
There are very few that I know of certainly. I'm excited to hear your thoughts on the Axi250, I didn't even realize it was publicly available.
Gable
Old 30th July 2019, 01:23 AM   #30
tapestryofsound is offline tapestryofsound  Scotland
That is a very beautiful hornspeaker. In my limited experience of building horns, the bigger the better. Even in mono they can sound very three dimensional. I have found that not pushing them too much with excessive eq gives a sound which is less tireless on the ear.
tapestryofsound
Big Two-Way Horn System for Mono?Hide this!Advertise here!
What to do when your new space doesn't fit your system? Mono, 2.1, something else? chazdrumzalot Multi-Way 34 1st September 2018 02:25 AM
Quite complex : Mono LP playback system Jamh Multi-Way 0 1st July 2016 05:02 PM
Pics new 4-way Azura horn system, plus BIG bass horn atilsley Multi-Way 64 5th May 2014 12:17 PM
Mono Horn System-Edgar Show Horn? fergs1 Multi-Way 4 23rd August 2011 04:13 AM
PA System Stereo or Mono 96tahoe PA Systems 8 4th April 2008 11:33 PM
Copyright ©1999-2019 diyAudio
