Help with Speaker Design
Old 21st July 2019, 05:44 PM   #31
10000 hz legend is offline 10000 hz legend  United States
I think going with the KEF LS50 is my best option. Is there a way I can add some crossover components to the LS50 OUTSIDE the enclosure? Not a dsp or Rca crossover. Id like to be able to power the whole setup with one amplifier. It looks all of these outboard crossover options will require two amplifiers.
Old 21st July 2019, 06:27 PM   #32
diyuser2010 is offline diyuser2010
While a passive crossover likely could be designed to roll off the KEF's and cross to the additional drivers, likely this will not be optimal, cost effective or keep the singular amplifier happy. ( load )
Your best chance for success is either a single amplifier module with two channels for each speaker, so two such amplifier modules ( 4 channels total ) with DSP integrated, or an outboard DSP unit with plural amplifiers.
Old 21st July 2019, 11:47 PM   #33
AllenB is offline AllenB  Australia
Sounds like a job for a conjugate filter (if indeed necessary).
Old 22nd July 2019, 08:56 PM   #34
koja is offline koja  Canada
passive circuits interact. so if they have an unknown passive filter built in adding blindly in front of it is not a good approach. active and bi-amp is the easiest route to take.
Old 23rd July 2019, 12:08 AM   #35
Tromperie is offline Tromperie  Australia
Source: LMS 7.9.2 on FreeNAS, PiCorePlayer * Storage: FreeNAS 11 * DIY PGA2310 * Amps: 8 x LM3886TF
Xover: 24dB @ 300 and 3kHz * Speakers: CNC cut 54 laminations * SB 10", SB 5", VIFA 1" * Remote: Squeeze Control
Old 23rd July 2019, 03:34 AM   #36
Again, thank you guys for all of the help. Much appreciated.. I apologize for getting ahead of myself. I still have a lot to learn.
I think I’ll probably buy something like the Parasound P6 that has bass management and just build those cabinets for the 2 10” woofers. This might yield me some good results without too much stress. A good first project.
One of you suggested going with 8” drivers instead of 10”s. My goal has always been to have a coaxial that has a large sound and can reach down into the 20s with authority with a little EQing, but I think my max volume for the two woofers is about 2.75 cubic feet if I want to keep the appearance I am aiming at. Am I better off giving a pair of 8’s some extra room in that enclosure, or. since I am bi-amping and am going to be using a little bit of bass boost am I better off with the 10’s?
Old 23rd July 2019, 03:59 AM   #37
Daytona50 is offline Daytona50  United States
Just saw your thread. Im interested in chatting with you about the build. I have designed speakers commercially and as a hobbyist for decades...and I'm in New Jersey. Ive worked on several coaxial designs and have experience with 10" woofers. PM me if you wish and I'll forward my number.
Old 23rd July 2019, 11:37 PM   #38
LineSource is offline LineSource  United States
LineSource's Avatar
"As I said, I have a very good idea of what I want to build. 6-1/2 coaxial in a sealed enclosure with 2 10inch woofers below it in a separate sealed enclosure."
In the Beginning...... the OP planned to use the 6.5" Tang Band W6-2313 coaxial speaker on top of two 10" woofers. A couple pic's for anyone following this thead for that first design... price range.
Old 27th July 2019, 02:54 PM   #39
Recap: Building a sealed 2x10" cabinet to put underneath a pair of KEF LS50s.
So I was looking at the Parasound P6 and Emotiva XSP-1 because they have bass management, but the crossovers only go to 140hz and 250hz, respectively. Will this be high enough to crossover to the KEF LS50's?
If not I only see two other options, which is going with an outboard crossover like the Rolls SX45, or going with the passive Harrison Labs RCA crossovers that they sell on Parts Express. I could buy several different RCA crossovers and find one that works best.
Thoughts?
Old 27th July 2019, 03:02 PM   #40
You can try the Mini-DSP 2x4 HD. Its a great development tool and totally flexible. Has Eq functionality which may be helpful for your 2x10 cabinets
Help with Speaker DesignHide this!Advertise here!
Speaker Design : Comprehensive list of Recommended Design Tools Hearinspace Software Tools 22 14th December 2018 02:54 PM
Rodin Speaker Design - New Speaker Design phillipmalecot101 Planars & Exotics 8 1st April 2015 08:08 PM
Strange similarities. Mixing engineering, Speaker design & Amp design ? aarvin2 Everything Else 103 7th October 2014 11:00 AM
Sound Design, a new book on innovative and interesting ideas in speaker design. Studio Au Multi-Way 3 8th April 2012 08:46 PM
Looking for Speaker Builder '99 article - Navigating Speaker Design percy Multi-Way 8 10th June 2011 01:20 PM
Copyright ©1999-2019 diyAudio
