I was looking at pairing a minidsp with an icepower amp.
I was curious if it was possible to have an 'adaptive' filter/eq dependent on the volume?
E.g. low to reasonable volumes have a bass boost (and lowered mids) to compensate for small drivers, but then roll it off at higher volumes?
How would I go about achieving this? THanks.
The 2X4 HD plug-in has a compressor/limiter that you could look at over at minidsp.com. You may have to apply bass boost in one section (PEQ or a peak filter) and let the limiter clamp down on the boost at higher levels. I think you're out of luck if you have a standard 2X4 minidsp.
You can do things like this with a BSS Soundweb London. It'd be a variation on this:
https://adn.harmanpro.com/site_elem...ating-a-bass-lift-volume-control_original.pdf
You just want to apply the equal loudness curves based on a volume lookup function.
Yes, I've found several solutions that follow ISO226 standard contours, but what if I want to custom tailor my own to overcompensate for smaller drivers and cabinet volumes?
Thanks.
