6.5" 2-way under 0
6.5" 2-way under 0
Old 13th July 2019, 10:05 PM   #1
BradH is online now BradH
Default 6.5" 2-way under $150
Hello,
First post - thank you for this site,
I'm looking to build 2 way stand mount stereo speakers. They will be driven by a class D amp from China. Subwoofer is not in the budget so 6.5" drivers or larger for adequate bass. The more bass the better if possible.
Budget is $150 CAD (about $120 USD) for drivers and crossovers. Bare bones crossover components are fine. I have the lumber. I'm not great at soldering and don't have measuring equipment. I am not bad with wood working though. FWIW
Would like something like Jeff Bagby Soprano but with larger woofers. Would like to use paper drivers if possible.
Listen to mostly rock, prog rock, ambient, house
Brad
Old 13th July 2019, 10:26 PM   #2
I haven't picked out a class D amp yet. So if there's one that works well with suggested speaker feel free to recommend.
Old 13th July 2019, 11:57 PM   #3
ernperkins is offline ernperkins  United States
ernperkins's Avatar
Look at the Classix II Bare Bones kit by Paul Carmody (slightly over your budget) and the Caritas Full Kit (well within your budget) by Jeff Bagby, both available at MENISCUS.
Old 14th July 2019, 12:34 AM   #4
LineSource is offline LineSource  United States
LineSource's Avatar
The 6.5" SB_Acoustics SB17NRXC35-8 is a popular paper cone midbass, and there are a few designs with the SB29RDC-4 1.1" dimple dome tweeter using a 1650-1800Hz crossover. Attached one example.
A 0.8cuft cabinet can reach -F3 ~ 42Hz. $130 - $150 for drivers and crossover parts. Selecting lower cost iron core woofer inductors and standard grade capacitors gets close to your budget. More info available on these drivers in different cabinet builds... like stepped baffle for time alignment and fewer parts LR2/LR2 crossover for lower total cost. Get latest prices at PartsExpress and Madisound(drivers)
Old 14th July 2019, 03:27 AM   #5
Gallen1119 is offline Gallen1119  United States
I built Paul Carmody’s Overnight Sensations and I really like them. I later added his Voxel sub for a little more bass. The OS alone sound pretty good and they are a proven design. I think you can get whole kit, including flat pack enclosure for about $140 US. Bare bones I sure is available cheaper. The crossover was very straight forward with point to point solders.
I was running them with a class D until I built Nelson Pass’s ACA which takes them to a new level entirely.
Edit: Just checked and meniscus audio has bare bone for $91 US.
Old 14th July 2019, 04:29 AM   #6
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
Consider 3e 3255 class d module, if you can find one.
Madisound have the SB 6" CAC on sale
A very good driver!
Old 14th July 2019, 03:38 PM   #7
ernperkins's Avatar
Great drivers, but I took his budget to be for the pair of speakers, not for each speaker.
Old 14th July 2019, 03:51 PM   #8
Thanks for the suggestions.
The SB acoustics stuff with the sb17 looks really nice, but it comes in about double the budget unfortunately.
Not a huge fan of the look of the Overnight Sensations, thanks though.
I'm going to go with the Classix II because I can get all the parts from Solen here in Canada and it comes in right on budget. I'll probably need some help a little later with assembling the crossover.
Question - Could I easily replace the BC25TG1504 with a BC25SC0604? Would it make much a difference? Heard nothing but great things about the latter one.
Brad
Old 15th July 2019, 03:08 AM   #9
ernperkins's Avatar
I personally wouldn't unless I was willing to remeasure and modify the crossover for the tweeter differences. The magic is in the designer's crossover and it was designed for a specific pair of drivers. You might get lucky because these tweeters are similar, but they aren't identical. And you would always wonder if it would have sounded better if you had built it as the designer had intended.
Old 15th July 2019, 05:32 PM   #10
Thank you, I'll leave the drivers as they are.
In terms of the cabinet. For aesthetic purposes I'd like to change it a bit, have a bit more space above the tweeter for a big roundover. Will that be a problem?
Brad
6.5" 2-way under 0Hide this!Advertise here!
Linn Preamp Model "Kolektor" - Display shows "Err4" after Switch-ON: What means this? tiefbassuebertr Analog Line Level 10 16th July 2018 01:55 PM
Speaker Cable "Seven Brain 11" from German's manufactur "Studio Stadthaus", Dortmund tiefbassuebertr Parts 0 10th November 2017 07:43 PM
5R4GY "RCA","FOUR PIECES" DOUBLE GETTER, USA 1945 made, mil-spec NOS NIB tubes ! vmed_cha_gr Vendor's Bazaar 0 15th September 2016 06:27 AM
Hitachi Servo/RF-Amp HA12158NT ("HA 12158 NT", HA12158, "HA 12158NT") from Linn Karik tiefbassuebertr Digital Source 6 27th June 2011 01:14 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Copyright ©1999-2019 diyAudio
