4ohm vs 8ohm midwoofer ...?
Old 12th July 2019, 02:42 PM   #11
adason is offline adason  United States
adason's Avatar
Here is 'laughably low' distortion for tube amp...see the significant distortion difference from 16 to 2 ohm (bottom to top)
Old 12th July 2019, 02:43 PM   #12
adason's Avatar
Even low distortion solid state amp behaves similarly. Adcom.
Old 12th July 2019, 04:51 PM   #13
ICG is offline ICG  Germany
ICG's Avatar
Well, you have to use the amp accordingly to its capabilities. To use a tube amp with a 2 Ohm load on the 8 Ohm tap is deliberately misusing the amplifier. If you do that, you can make all amps look bad, you just have to set the margin 'challenging' enough. I also wrote to avoid 2 Ohm altogether. At 10W and 4 Ohm its distortion is below 0,45%, that is actually still much lower than the most speakers. And don't forget, it's mostly the (often even wanted) K2.
That is actually laughably low distortion compared to the distortion of most speakers, even with the 2 Ohm (ab)use.
I had a Déjà Moo - I've seen that BS before!
Old 12th July 2019, 06:41 PM   #14
adason's Avatar
That was just an example from stereophile magazine. Even if they would use 2 ohm tap with 2, 4, 8 and 16 oh load, the result would indicate increasing distortion with decreasing load.
But I do not want to argue anymore, I do not care.
Those laughably low distortion amplifiers tent to sound like crap sometimes
Old 12th July 2019, 10:58 PM   #15
ICG's Avatar
I agree. And you can't pair every speaker with every amp. The worst is when ppl just buy the 'test winners' and then realize it doesn't sound as heavenly they thought it would surely do.
Old 13th July 2019, 06:19 AM   #16
denibeni is offline denibeni
It hink you mean, increased distortion with increasing load?
Actually if you decrease the speaker impedance, the amp load increases and not decreases. Or did i miss something?
Old 13th July 2019, 12:12 PM   #17
adason's Avatar
right...mean to say resistance instead load
4ohm vs 8ohm midwoofer ...?Hide this!Advertise here!
is this 4ohm or 8ohm Moze Multi-Way 11 29th February 2016 01:40 AM
8ohm speakers 4ohm tap 5u4 Tubes / Valves 1 17th April 2009 11:22 PM
4ohm and 8ohm LR4 xo LukeDuke Multi-Way 1 17th April 2008 05:09 PM
8ohm or 4ohm? adrrad Chip Amps 5 21st October 2007 04:29 PM
4ohm Sub driver to 8ohm Sub amp? WBFAir Multi-Way 10 31st March 2007 01:29 AM
Copyright ©1999-2019 diyAudio
