Freq measurements and Hypex Filter Design adjustments
Old 6th July 2019, 05:40 PM   #21
Steve2111 is offline Steve2111
Default Freq measurements and Hypex Filter Design adjustments
How is it that the nearfield measurement for woofer looks nothing like manufacturer's graph? It starts dropping to lower at lower freqs from 600Hz?????
Old 6th July 2019, 05:56 PM   #22
ctrlx is offline ctrlx  United Kingdom
check your acoustic measuring setup by doing a physical loop back.
the response should be very flat, +/- 0.05dB and +/- 0.1deg should be attainable
take near field tests ungated, no smoothing is needed.
Old 6th July 2019, 06:01 PM   #23
Thanks CTRLX
How do loop back?
Attach manufacturers Woofer Focal Audiom 15WX
Doesn't look like my measurement
Old 6th July 2019, 07:43 PM   #24
CharlieLaub is offline CharlieLaub  United States
Did you turn off the filters before taking the latest measurements in post #19???
It sure looks like your woofer is being fed by a 500Hz HIGHPASS filter! It would make more sense if the woofer used a LOWPASS filter around 500Hz. Could that be the source of the drooping response issue?
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Old 6th July 2019, 07:48 PM   #25
Turned off all filters
Muted all drivers except Woofer and response looks like a Mid range!!!!
Old 6th July 2019, 07:50 PM   #26
And as I said, the measurement looks nothing like the manufacturer's!
Old 6th July 2019, 08:23 PM   #27
I have to agree with you... that does not look right at all for a 15" woofer!
Is there any way you can temporarily connect the woofer to a different power amplifier, any one at all, and test using that? Doing that would help to determine if the problem is the driver, or with the Hypex amp/DSP unit.
Old 7th July 2019, 03:05 AM   #28
Difficult now because speaker wired via Neutrix. Before going "Digital" the driver sounded better with passive xover and valve amp. In theory the DSP way should sound better.
Old 7th July 2019, 08:06 AM   #29
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
It just takes more learning by doing...
Ask a friend to visit and check connections and settings, you get blind to basic mistakes.
Been there, done that!
Radikal aktivist AINOgradient speaker project
Old 7th July 2019, 09:02 AM   #30
Thanks Juhazi. Yes I'm there now, but as I'm no electrical engineer I'm experimenting with caution so as not to blow a tweeter or amp.
Well I've re done the nearfield for Woofer and Mid and got more logical results.
I was told how to mute the channels. As when I ticked the Mute box the channel did not stay muted, I disconnected the cables for Mid and tweeter channels. Perhaps the Hypex Dlcp or amps did not like that???
Anyway to mute a Channel you have to reduce its Gain to -96db. Not via Mute button! I don't know whether I have ever read that in the instructions and I cannot read minds!!
So I attach better looking freq responses for Woofer and Mid (not scaled because different volume settings) and no filters.
Freq measurements and Hypex Filter Design adjustmentsHide this!Advertise here!
Capacitor to filter low freq buzz? steve71 Multi-Way 15 20th January 2009 05:48 PM
Freq resp measurements on the Apex Jr 3" M&K twin cone? Brisso57 Multi-Way 0 11th October 2007 08:38 PM
Notch filter at x'over freq. of woofer? grantnsw Multi-Way 23 25th August 2006 12:39 PM
problem with freq filter Magnat biatch Multi-Way 1 27th November 2005 04:40 PM
Freq Response Measurements of PHL drivers akunec Multi-Way 18 20th February 2005 12:39 AM
Copyright ©1999-2019 diyAudio
