Freq measurements and Hypex Filter Design adjustments
Old 2nd October 2019, 02:00 AM   #211
PLB is offline PLB  United Kingdom
Hi Steve,
Are you aware of the "Pink Cutoff(Hz) function in ARTA that has a selectable HP filter used for making measurements on tweeters?
When a measurement is made with this function set to say 1KHz, the inverse of this function is then applied to the data after aquisition. This provides you with a frequency response of the speaker without the response of the 1KHz filter!
So you don't need to apply a 1KHz crossover to the tweeter in order to protect it from excesive low frequency excursion.
Peter
Old 2nd October 2019, 08:48 AM   #212
Steve2111 is offline Steve2111
Default Freq measurements and Hypex Filter Design adjustments
Hi Peter,
No was not aware. But I see that it is not available under "Sweep"?
Not used Pink Noise for measurement before
Old 6th October 2019, 07:16 PM   #213
Set up my living room for measurements again.
Just a few questions on ARTA set up.
I'm going to be measuring Tweeter, Farfield (1meter)
Going to risk HighPass LR4 at as low as 500Hz. (don''t know how to do with Pink Noise, Peter, as other drivers measured with Sweep)
ARTA Impulse response measurement/ Signal recording Window
Under Sweep generator:
Sequence length, 16K to 256K which and why?
Sample rate, I presume 48000?
Output Volume 0?
Log freq sweep - tick or not?
If later measure with Hypex FD (not done before) anything to consider?
Old 7th October 2019, 02:41 PM   #214
AllenB is online now AllenB  Australia
Sweep is good, it allows you to gate.
Regarding length.
0=0dB, normal full output.
Choose log sweep.
Old 7th October 2019, 06:54 PM   #215
Thanks Allen
Trying to understand the length link
Old 31st October 2019, 05:57 PM   #216
Focal confirm TD5 XO at 2.5KHz (not 2KHz) You were right YSDR!
Also 15WX XO OK at 500Hz
ATC confirm they use range for SM 75-150S of 380Hz to 3.5KHz
If I use XO freq of 2.5KHz for the TD5, is the tweeter measurement in Post 201 with highpass at 1KHz good enough? The Highpass at 1KHz seems to affect the response from 2K downwards
Old 3rd November 2019, 05:50 AM   #217
YSDR is offline YSDR  Hungary
Yes, 1kHz highpass is usable for measurements for 2kHz and up, 2.5kHz and up is even better imo. My advice for xo point is still somewhere 2.5-3kHz.
Here is two 1kHz highpass response, one with BW2 (2nd order Q=0.71) and one with LR4 (two cascaded 2nd order BW2) for help.
As we an see even the LR4 is only around 0.5dB down at 2kHz. You can create these target responses in ARTA with ease, and it's useful.
Old 11th November 2019, 07:44 PM   #218
Just some questions on ARTA
When try to truncate impulse measurement get:
Error:Gated length < 128samples
Need to go beyond 1st reflection in order to not get that message. See attached Trunc.jpg
Then with smoothing 1/1 get approx +/- 1dB see smooth1-1.jpg
with smoothing 1/24 get approx +/- 7dB of the same measurement See 1-24.jpg
Old 11th November 2019, 07:54 PM   #219
64k Sequence length is enough, but your impulse response looks strange to me. Please add little more gain in ARTA for better visualization.
Old 12th November 2019, 08:42 AM   #220
Impulse with 64K Sequence
Freq measurements and Hypex Filter Design adjustmentsHide this!Advertise here!
Capacitor to filter low freq buzz? steve71 Multi-Way 15 20th January 2009 06:48 PM
Freq resp measurements on the Apex Jr 3" M&K twin cone? Brisso57 Multi-Way 0 11th October 2007 09:38 PM
Notch filter at x'over freq. of woofer? grantnsw Multi-Way 23 25th August 2006 01:39 PM
problem with freq filter Magnat biatch Multi-Way 1 27th November 2005 05:40 PM
Freq Response Measurements of PHL drivers akunec Multi-Way 18 20th February 2005 01:39 AM
Copyright ©1999-2019 diyAudio
