Freq measurements and Hypex Filter Design adjustments
Old 30th June 2019, 08:20 PM   #11
YSDR is offline YSDR  Hungary
Originally Posted by Draki View Post
That would be the acoustical slope. Important to distinguish from the electrical slope generated by the x/over. That could be anything, and most likely it will not be LR4 - but whatever sums up with the driver's natural roll-off to get the acoustical target.
Impossible to tell without measuring.
Troels crosses with electrical 2nd order to achieve 4th order acoustical high-pass: ATC-SM75-150
You are right, but if we talking about a DSP solution, as we did here, first you equalize the driver response to flat, then apply the desired filter slope and you get the exact acoustic response, be it BW2, LR4 or whatever.
Of course, you can combine the original acoustic slope of the driver with a DSP slope if you want.
Old 30th June 2019, 08:27 PM   #12
Steve2111 is offline Steve2111
Are you familiar with Hypex Filter Design?
Old 30th June 2019, 08:29 PM   #13
Who?
Old 30th June 2019, 08:31 PM   #14
You. Denibeni. Because that is what I would like help with once I have taken the measurements
Old 30th June 2019, 09:38 PM   #15
Draki is offline Draki  Macedonia
EQ-ing low end of a mid driver to flat - a substantial lift at the lower frequencies - and then applying the 4th order HP filter is overdoing it. Yes the DSP can do it but it looks like the reason for doing it is because "it can".
A well behaved unit like the ATC here will (and it does) react well with a simple 2 order HP.
EQ-ing flat(tish) works well for the high end, i.e. for LP filters.
Above IMO of course, many ways to skin a cat.
Old 5th July 2019, 09:11 PM   #16
Default -freq-measurements-hypex-filter-design
OK just done nearfield measurements. Mic 0.5cm from dustcover. Was not able to mute mid and tweeter so some freqs slipped in? ASIO Control panel: sampling rate 48KHz Buffer size 1024
I have 1/1 smoothing and 1/24 smoothing. Gated apparently reliable above 100Hz Not gated apparently all reliable?? In all these mesurements the filters were not diasbled so this woofer had Low Pass LR4 at 500Hz
I don't understand these freq responses
Old 5th July 2019, 10:40 PM   #17
CharlieLaub is offline CharlieLaub  United States
OK just done nearfield measurements. Mic 0.5cm from dustcover. Was not able to mute mid and tweeter so some freqs slipped in? I have 1/1 smoothing and 1/24 smoothing. Gated apparently reliable above 100Hz Not gated apparently all reliable?? In all these mesurements the filters were not diasbled so this woofer had Low Pass LR4 at 500Hz
This is basically all wrong.
Disable all filters. Turn off all drivers except the one you are measuring. Then redo the nearfield measurement on each driver, one at a time. You should be able to use a pretty long window (or no gating at all). Use only 1/24th or 1/12th octave smoothing. Make sure to save BOTH amplitude (SPL) and phase data, minimum phase if possible, using the FRD file format if possible. Go back and check my tutorial if it is helpful.
You really only need to do this for the woofer, but it wouldn't hurt to do it on the midrange as well.
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Old 6th July 2019, 10:27 AM   #18
Default Freq measurements and Hypex Filter Design adjustments
I've done gated and not gated of only Woofer as per screenshoots attached. Also attach manufacturers graphs of tweeter mid and woofer responses. My measurement don't look that good?
Old 6th July 2019, 06:17 PM   #19
I don't think images were uploaded
Old 6th July 2019, 06:19 PM   #20
Also include manufacturer's graphs
Freq measurements and Hypex Filter Design adjustmentsHide this!Advertise here!
Capacitor to filter low freq buzz? steve71 Multi-Way 15 20th January 2009 06:48 PM
Freq resp measurements on the Apex Jr 3" M&K twin cone? Brisso57 Multi-Way 0 11th October 2007 09:38 PM
Notch filter at x'over freq. of woofer? grantnsw Multi-Way 23 25th August 2006 01:39 PM
problem with freq filter Magnat biatch Multi-Way 1 27th November 2005 05:40 PM
Freq Response Measurements of PHL drivers akunec Multi-Way 18 20th February 2005 01:39 AM
Copyright ©1999-2019 diyAudio
