Synergy Horn with AMT
Old 24th June 2019, 09:03 AM   #11
de45dd is offline de45dd
Originally Posted by LewinskiH01 View Post
Considering the Beyma TPL-150H is well behaved above 2kHz, wouldn't an extension of the Beyma horn such that it accommodate the midrange drivers be a good place to start? Extend to a size per Bwaslo's spreadsheet for the midrange cutoff frequency, had maybe 4x 4" midranges (2 per side of the TPL), down to 30 or 400Hz...bad idea??
The idea in general is not bad but there are a few reasons I donīt want to do that.
1. I wanted to use the Mundorf instead the Beyma
2. Due to optical reasons the Horn has to mach to the 15 inch woofer size and I also want to build the Horn with MDF same as the complete front of the box to have an common look.
3. I wanted to use 6,5 woofers to cover the complete midrange down to 200Hz. The 6,5 woofers will not fit physically on the smaller TPL Horn.
I donīt think that any 4 inch woofer is able to handle that low without beeing extremely stressed.
Old 24th June 2019, 01:38 PM   #12
most important question for me still is if I can put the openings in the middle of the horn or I have to put them in the edges?
This will decide the distance to AMT-diagraphm and then which midwoofer-size I can use and which crossover point I can make.
Old 27th June 2019, 07:09 PM   #13
where are the Unity horn specialists? Does the Openings Need to be in the edges of the horn?
Old 27th June 2019, 07:47 PM   #14
RobWells is offline RobWells  United Kingdom
RobWells's Avatar
Yes put them in the corners (not a specialist but I have read a bit about the unity / synergy horns)
The reason is that the ports will have the least detrimental effect on the tweeter response when placed in the corners.
Old 27th June 2019, 08:18 PM   #15
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
If you have a 3D printer, I've found that nothing outperforms the mid-range taps that I use. Basically the idea is a loooong ribbon shaped tap. By making the tap extra long, you can make it skinny. And skinny taps screw with the overall response less.
In my Ribbon Unity project, the mid-range taps were perpendicular to the wavefront. In my current project, they're in the corners. Both options have their advantages.
JBL uses parallel mid-range taps in their Vertec speaker.
EAW uses fractal taps in Anya.
Old 27th June 2019, 10:19 PM   #16
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
For what it's worth (maybe not a lot), I was never able to get taps in the corners to work out right. Not that I tried a lot of iterations. But the CoSynes taps weren't in the corners, and worked out pretty well (luck). And when I tried to redo them with taps in corners in a set of REALLY PRETTY wood veneer preserving waveguides that were otherwise similar, the off axis response was horrid. My thought then was that maybe it was because moving the taps to the corners moved them away from each other.
Synergy Horn with AMT-dimensions-photo-png
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 28th June 2019, 05:52 AM   #17
Very interessting post! So what hear from you, itīs maybe the best to start with an skinny ribbon shaped tab.
Which advantages and disadvantages do you see between the differnt placement of the tabs?
Also very interessting. Do you have an picture of the CoSynes Horn (where the tabs where not in the corners)?
Do you still have measurments of the both version (off axis problems)?
Old 28th June 2019, 06:22 PM   #18
bwaslo's Avatar
Measurements are probably on an old hard drive somewhere, but not readily available. I do have this photo from during construction which sort of shows how the ports look (Patrick has the actual speakers, he could probably provide a better photo).
Synergy Horn with AMT-assembly-jpg
The horns are rectangular, and moving the ports into the corners changed them from a square configuration (all the ports the same distance from their neighbors and as close as they could be to center) to rectangular (further apart horizontally). It also changed the paths they took slightly (because each ports were cut into edges of two walls rather than into just a single wall). A complication was that the tweeter used could not go down very low so the midranges had to perform higher in frequency than a lot of syn designs, so mids being close was a pretty important thing.
Old 28th June 2019, 06:31 PM   #19
bwaslo's Avatar
Another maybe interesting data point (well, not data, more anecdote) is that when I did the first large 3DPrinted waveguide, the midrange ports seemed to be virtually invisible to the tweeter. I could cover them with duct tape with little change to the tweeter response, with the ports not in corners -- they were arranged in a square. The originally placed woofer ports, however, played hell with the tweeter response, even though I wouldn't have expected too much tweeter radiation to reach there. I moved those further out and made them smaller to get that interraction acceptable.
Old 28th June 2019, 06:34 PM   #20
DPH is offline DPH  United States
Some sort of a critical diameter/X-section makes them visible/invisible, Bill?
I'm also forgetting what shape you made your printed ports.
Happy DIYing, Daniel
Synergy Horn with AMTHide this!Advertise here!
Synergy horn for 135 dB+ Thijs666 Multi-Way 107 24th November 2018 04:07 PM
horn, bandpass, horn, synergy? fotsinijts Multi-Way 32 31st August 2018 09:30 AM
M2 Synergy Horn Patrick Bateman Multi-Way 43 23rd December 2017 02:08 PM
DIY Synergy horn paulspencer Multi-Way 53 5th December 2015 09:29 AM
synergy like horn, using CD rvrazvan Multi-Way 5 4th November 2011 08:28 AM
Copyright ©1999-2019 diyAudio
