Which Inductor for (First Order) woofer low pass??
Old 19th June 2019, 11:55 PM   #31
Wikkid is offline Wikkid  United States
Wikkid's Avatar
Originally Posted by ICG View Post
If you don't like my help or me posting here, I'll stop. Do you?
Alright then..
Perhaps we got off on the wrong foot....
I see that you are sincerely trying to help.
So what exactly are you proposing?
Old 20th June 2019, 09:17 AM   #32
ICG is online now ICG  Germany
ICG's Avatar
To go passive, you need a much higher Qts so it reaches the level of the Supravox. Since you don't want that, there are only two things as solution.
1. Use more 15" drivers in the sub range and push the Qt slightly, likely 18dB crossover. A 2nd 15" would give you +3dB by double the cone area and +3dB because the halved impedance doubles the power drawn from the amplifier. You mentioned a tube amp. I don't know if the amp would be happy about the lower impedance. Also, the coils would get much more expensive since lower (half) impedance means double the inductance and for 18dB you need two per side. The DCR of the coils will rise the Qt but added DCR ofcourse decreases the spl. A lot of compromises and 'IF's.
2. You stay at an active solution, preferable with a dsp. That would solve all your problems and still be cheaper.
I had a Déjà Moo - I've seen that BS before!
Old 20th June 2019, 10:28 AM   #33
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
A-hem..!
Everything under and above heaven is in utter chaos
mare monstrum
Old 20th June 2019, 10:36 AM   #34
ICG's Avatar
Originally Posted by picowallspeaker View Post
A-hem..!
Good catch. Thank you, ofcourse it's the other way around. I was writing about twice as much coils costing ~twice as much than 6dB and was editing while writing and obviously went braindead while doing so. Sry.
Old 20th June 2019, 01:00 PM   #35
tsmith1315 is offline tsmith1315  United States
tsmith1315's Avatar
Originally Posted by denibeni View Post
In response to the original question, I think it is almost irrelevant which inductor you would choose.
It is irrelevant, because the level of precision and accuracy that the OP is basing his decision on won't happen in a single-element passive filter operating this close to fs
This is why ICG suggested an active filter in post #19, to test and see if 1st order would be satisfactory before attempting to design a passive implementation.
All IMHO, this is.
Tim
Old 20th June 2019, 01:22 PM   #36
denibeni is offline denibeni  Europe
All IMHO, this is.
Well said, but needs to consider that a 1st order active filter is usually not equal to single element passive filter. Mainly due to the variable impedance of the driver.
Old 20th June 2019, 01:58 PM   #37
Mrcloc is offline Mrcloc  South Africa
That is actually helpful! Thank you!
Fixed.
Right. I'm reading this thread as a technical exercise to learn a bit more. I think ICG and OP have a slight misunderstanding. I believe OP wants to level the FR, not cut it after 70/75 Hz.
Old 20th June 2019, 02:00 PM   #38
tsmith1315's Avatar
Right you are denibeni, thus the embedded "attempting to design" disclaimer.
Mrcloc, the OP indicated 70-75Hz low pass filter in the first post.
Tim
Which Inductor for (First Order) woofer low pass??Hide this!Advertise here!
Simplest 1st order high pass and low pass filter LeBurgh Analog Line Level 2 10th January 2017 09:46 AM
Help with Tweeter Inductor value for 2nd order L/riley mart.s Multi-Way 1 14th December 2008 03:56 AM
2nd Order Tweeter + 3rd Order Woofer = OK? Jay Multi-Way 3 12th September 2005 12:12 PM
1st Order Tweeter, 3rd Order Woofer? Jay Multi-Way 8 8th May 2004 09:29 PM
X-BOSOZ 1st order inductor filter Ignatz Pass Labs 14 17th April 2003 10:01 PM
Copyright ©1999-2019 diyAudio
