Troy's new line arrays
Old 17th June 2019, 03:29 PM   #1
troystg is offline troystg  United States
troystg's Avatar
Default Troy's new line arrays
Assembling...
8 x 18W/4831G00
8 x NeoCD2.0
I needed some alone time to get this done...
P_20190617_092957.jpgP_20190617_101846.jpgimage-20190617_101922.jpgimage-20190617_102421.jpg
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 17th June 2019, 03:32 PM   #2
adason is offline adason  United States
adason's Avatar
why are you facing tweeters inside the box?
nice work! good luck!
Old 17th June 2019, 03:36 PM   #3
S4m is offline S4m  Germany
S4m's Avatar
@ adason: I guess it's just for checking if everything fits as planned
Very nice done, good job!
Old 17th June 2019, 04:10 PM   #4
celef is offline celef
Wow, cool project! Have you ever considered seas diamond domes instead?
Old 17th June 2019, 04:18 PM   #5
hotiron is offline hotiron  Scotland
hotiron's Avatar
OH boy. Your wife gonna love you. Great work.
If you give up easily Dont start!!
Old 17th June 2019, 06:33 PM   #6
troystg's Avatar
Finished and in place.
DCX2496 to add and dedicated amps.
The old speakers are SS Revelator tweeters, B&W 6.5" mids sitting on top of servo controlled aluminum 10's.
MiniDSP and 4 x UcD180's.
New will start with DCX2496 and a pair of stereo amps but I am debating the miniDSP icepower plate amps...P_20190617_131952.jpgP_20190617_131927.jpg
Troy
Old 17th June 2019, 07:20 PM   #7
troystg's Avatar
Thanks all, they're not tiny little b0$e.... And hopefully they don't sound anything like them either.
Wife is ok with them. I give her a sewing room, she gives me the tv area..
Now to make interconnects to "sew" it all up. Yeah, the wife doesn't get my humor either... :-)
Troy
Old 17th June 2019, 07:44 PM   #8
kipman725 is online now kipman725  United Kingdom
kipman725's Avatar
Send a message via MSN to kipman725
are you doing any shading or phase shifts to focus the array?
Old 17th June 2019, 08:29 PM   #9
troystg's Avatar
The two center mids are in series for an 8 Ohm load, he other 6 in series for a 24 Ohm load and the two strings paralleled.
Troy
Old 17th June 2019, 09:22 PM   #10
Gnobuddy is offline Gnobuddy  Canada
Very nice carpentry!
Too bad you don't have quite enough drivers to do the job properly.
Those line arrays should be twice as tall, you just need to cut holes in your ceiling and roof to fit them. And there should be at least four line arrays on each side of the fireplace, not just one. And you don't need a fireplace, it should be turned into a subwoofer, with at least four 18" drivers, and the chimney extended and tuned to act as a transmission line.
-Gnobuddy
Troy's new line arraysHide this!Advertise here!
NSB line arrays for PA use? Spasticteapot PA Systems 1 1st April 2007 12:32 PM
karma line arrays karma Multi-Way 31 23rd April 2006 02:48 AM
Do line arrays... LizardBrain Full Range 4 23rd March 2006 05:21 AM
Line Arrays Down Under deaf monkey Multi-Way 0 14th December 2004 06:03 PM
Line Arrays Won Multi-Way 33 10th February 2002 10:20 PM
Copyright ©1999-2019 diyAudio
