Constant directivity speakers - are they rare?
Old 19th June 2019, 02:05 AM   #41
bbutterfield is offline bbutterfield  United States
Originally Posted by Daihedz View Post
Some additional explanations/illustrations to my previous post:
First picture shows how the vertical null can be set to virtually any angle within a Horbach-Keele array by adjusting the target beamwidth.
To check wheter this will behave as expected, I built a test setup with a Horbach-Keele array (2nd picture). A first measurement was made with the complete array driven as a regular HK array (ex w-boxed dipole woofer). Another measurement was made with only the tweeter and the 3 drivers of the bottom half of the array (ex w-boxed dipole woofer), this time driven by a LR4-xo (same xo-frequencies as in the HK-xo). So this latter measurement was mimicking a more or less standard LR4-setup.
Picture 3 shows the resulting impulse response. LR4 (green) shows a distinct floor reflection after some 3.2ms. Whereas HK (red) shows only a weak (tweeter) reflection at 3.2ms.
This is why I think that HK ist a nice approach to cancel floor and ceiling reflections. One could place the tweeter (symmetry point of the array) to a hight in order to provide a good compromise between floor an ceiling reflections rejection. And HK is intrinsically constant directivity in the vertical plane. So you get best of all worlds as a reward for a rather monstrous array.
HK filters and numerous amps are unnecessary. In order for HK filters to work the way they are intended, you first have to linearize a minimum phase device. In contrast, I've already shown how to do the same thing with passive filters (and a single amp) and minimum phase target response curves in my thread on fractal arrays, which are generalized (can incorporate vertical and/or horizontal directivity).
Fractal Array Straight CBT with Passive XOs and no EQ
It's slow to start because bad assumptions were made by those trying to verify the design concept, but it gets there eventually. There's even a how-to on post 58 Fractal Array Straight CBT with Passive XOs and no EQ
Old 19th June 2019, 02:11 AM   #42
Originally Posted by Brett View Post
And then you have time of flight differences between the ends and centre of the line that makes them sound "phasey" to me. Never heard a long panel I liked, nor a line.
I certainly don't have that problem with my arrays. My arrays are nested, not side-by-side. My tweeter is about 2.5" tall, and the array grows from there. Many have doubted the coherence of the array... until they heard it.
Old 19th June 2019, 02:19 AM   #43
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
I agree.
My current project is based on a similar idea. Multiple amps and HK filters would be nice, but I can get very close using passive 3rd order filters.
Old 19th June 2019, 10:46 AM   #44
Daihedz is offline Daihedz  Switzerland
Originally Posted by Patrick Bateman View Post
Trying to convince someone to do a four way WMMTMMW with FIR filters as a first project is, ummm, "challenging."
No worries - I am not talking about a beginner's project at all. I am talking about an option to provide CD (=title of the thread), matched along with the intriguing option to cancel/attenuate floor/ceiling reflections as well. Because of bbutterfield's / brett's comments.
Horbach-Keele has been developed for professional use (Harman/JBL), has been patented and will for most hobbyist's motifs be a too expensive/complex way to provide CD, or in the words of the authors, a constant beam within a vertical array. But despite the patent and the complexity, as a non-commercial DIY-er you are free to try this one out at home. I dont know of any commercial implementations outside of JBL by now, which may be attributed to the fact that there is this patent.
And by the way(s), my test array is not (symmetric) 4-ways WMMTMMW, it's an asymmetric 5-ways WMMTMMW[W], and should be even a much huger 6-ways if you want a really deep bass extension with dipole characteristic. The 5th way is a non-CD, 65Hz-140Hz W-Dipole-Bass on the floor, which will not cause any floor reflection due to the vicinity to the floor. So this approach might be vertically CD from 150Hz to 1.5kHz, above 1.5kHz you may no more deal with a dipole configuration for CD, but with a suitable waveguide. In the transition region from 1.5kHz to 3...4kHz you might expect some beam irregularities, though. I did not measure that.
A boxed monopole configuration (as in the original paper) would make bass extension much easier and the look much more conventional.
Old 19th June 2019, 11:04 AM   #45
… In order for HK filters to work the way they are intended, you first have to linearize a minimum phase device. In contrast, I've already shown how to do the same thing with passive filters (and a single amp) and minimum phase target response curves in my thread on fractal arrays, which are generalized (can incorporate vertical and/or horizontal directivity).
No problem, linearizing the minimum phase devices is easily done by DSP. Have a look e.g. at Uli Brüggemann's Acourate, which also comes along with a straightforward and elegant HK filters generating option (Introseite - AudioVero).
I have read your thread, and I did appreciate all the simulations. Still: Do you have set up a working prototype, and can you post some measurements to check the real outcome? Would be most interesting. I have the strongest interest in archieving similar results as in HK, but with a leaner approach!
Old 19th June 2019, 11:51 AM   #46
I noticed that you can't receive PMs.
Old 19th June 2019, 04:19 PM   #47
[Off-topic answer:] Right. You are welcome to post in open forum mode, e.g. visible to all whatever you would like to in reply to my input(s). It might hopefully enrich the discussion and be of interest to all others also.
Old 19th June 2019, 06:16 PM   #48
Soldy is offline Soldy  Germany
Wow, great Feedback. I will have a Lot of Reding Material for the weekend
Constant directivity speakers - are they rare?Hide this!Advertise here!
R16 constant directivity dipoles gainphile Multi-Way 70 15th September 2015 02:15 AM
S16 - Constant Directivity Dipoles gainphile Multi-Way 151 31st October 2014 12:35 PM
Constant Directivity Cornerhorns Wayne Parham Multi-Way 30 19th January 2011 04:28 PM
Constant Directivity Horn EQ Horizons Multi-Way 4 19th December 2008 11:41 AM
Constant directivity EQ Saurav Multi-Way 11 19th May 2008 02:41 AM
Copyright ©1999-2019 diyAudio
