Onken with Beyma 15XA38Nd
Old 23rd June 2019, 09:25 PM   #11
GM is offline GM  United States
GM's Avatar
Looks good from what I can tell, but too small to blow up.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 24th June 2019, 05:48 AM   #12
hifisucks is offline hifisucks  Germany
hifisucks's Avatar
GM
Whadayamean... blow up?
Old 24th June 2019, 06:11 AM   #13
hifisucks's Avatar
I was very dissapointed about what was coming out at first... took the 1,5dB bridge out...
but sounded awefull! No midrange and week bass...
Then I took the pyramid foam damping completly out and put the bridge in again...
WOW! What a spectacular event! I was at the concert finally! And that with only a few watts... :-)
So, with this perticular Beyma, no damping whatsoever is needed! Just the raw guts :-)
All the best!
Old 18th July 2019, 07:52 AM   #14
Coaxer is offline Coaxer
That is a real nice speaker. Do you have any measurements and could you please post some plans as I am searching for the right enclosures for my beyma 15" at the moment. Thank you!
Old 18th July 2019, 09:39 AM   #15
GM's Avatar
The pictures are too small and don't expand.........can't see them clearly.
GM
Old 5th September 2019, 06:53 PM   #16
hifisucks's Avatar
Better pics...
DSC01071 — imgbb.com
DSC01072 — imgbb.com
DSC01073 — imgbb.com
DSC01074 — imgbb.com
DSC01075 — imgbb.com
https://ibb.co/YZwWNfK
https://ibb.co/09JL1z8
Old 5th September 2019, 09:28 PM   #17
vladimir is offline vladimir  Belgium
vladimir's Avatar
Bravo, a very nice and inspiring project. I still have old pair of 15xa, my project was stopped by the hughe box requirement and non availability of a crossover. I may give them a second chance having seen your nice build
Old 5th September 2019, 10:10 PM   #18
Draki is offline Draki  Macedonia
I always take 18mm multiplex with a few inforcements around the inside...
original plan downsized to fit the Beymas...
Crossover I build from a russian site... with original specs...
You do know that the metal screws thru the coils are changing their value, don't you? Did you measure them as mounted, with the metal "core"?
Old 6th September 2019, 01:10 AM   #19
GM's Avatar
Better pics...
Old 6th September 2019, 05:32 AM   #20
hifisucks's Avatar
Very interesting... I must try some wooden screws one day... :-)
Thankyou!
Onken with Beyma 15XA38NdHide this!Advertise here!
Speakers based on beyma 15xa38nd Zoef Full Range 45 15th February 2020 03:23 AM
Beyma 15XA38Nd network hifisucks Multi-Way 10 13th June 2019 12:46 PM
Beyma 15XA38ND for HT?? uniquepattern Multi-Way 0 19th January 2017 08:12 PM
WTB: Beyma 15xa38nd matsj Swap Meet 2 5th June 2012 09:50 AM
Additional info for the Beyma 15XA38Nd eeyore Multi-Way 0 17th April 2011 12:20 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
