Hi End speaker box terminal and class D plate amp for sub horn
Old 14th June 2019, 08:49 PM   #1
Best Hi End is offline Best Hi End
Default Hi End speaker box terminal and class D plate amp for sub horn
I'd appreciate any recommendation for excellent quality Hi End speaker box terminal (non Chinese and not bi wire) for Hi End active 4 way speaker .
Also,I need recommendation for non Chinese super quality Hi End class D
8 Ohm plate amplifier for active sub horn with minimum 500watts per channel on 8 Ohm preferably with DSP with minimum 16k taps
Hi End speaker box terminal and class D plate amp for sub hornHide this!Advertise here!
Hi End speaker box terminal and class D plate amp for sub horn Best Hi End Multi-Way 0 14th June 2019 08:44 PM
Speaker terminal cup help lotus_guy Multi-Way 5 21st March 2016 12:06 AM
MTX RT251D Getting 40V across speaker terminal turbosundance Class D 4 13th August 2014 09:08 PM
Class A buffer using LM317 3 terminal reg's Circlotron Solid State 39 9th August 2011 05:10 PM
APWorkbench: top-class development tool for Sound Terminal amplifiers mv737 Chip Amps 5 22nd June 2010 12:56 AM
Copyright ©1999-2019 diyAudio
