DIY speaker recomendations, maybe Garnacha?
Old 11th June 2019, 11:48 PM   #11
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Which kit ? all the speakers listed here are horrible, except the ones the OP owns : the Zaphs ZR 71
It's like learning sex during the Victorian era: you get to the wedding night and there are many things to do that you never imagined.
Old 12th June 2019, 08:25 AM   #12
pguerin is offline pguerin  France
But Mk2 is, from what i read, an improvement made to handle some of the complaints regarding the tweeter.
The main difference vs mk1 and mk2 is the crossover between the upper second woofer, LR4 filter slopes for the mk1 and LR2 filter slopes for the mk2. Point of crossover is lower for the mk2, 2 khz and 3.3 khz. The two versions may sound a little different, but IMHO differences are subtile. The mk1 beeing an open design, I think it may be cheaper to build the crossover.
Concerning the tweeter, some people have complain about the D2608/810921 sounding harsh, in most of the case it can be fixed by levelling the tweeter level and/or adding an RLC notch filter around 10 Khz.
BR Pascal
Old 16th June 2019, 03:32 PM   #13
Smoothy is offline Smoothy  Sweden
Well thanks you so much for this insightful feedback, really helps me and others reading this thread a lot! Seriously tho, care to explain your thoughts?
Old 16th June 2019, 08:37 PM   #14
BR Pascal
Thanks for the info .
Anyone have any idea about how Jeff Bīs Solstice handels compared to the Nomex? Because very weak exchange rate and weird pricing over all they have about the same price here.
Old 17th June 2019, 08:24 PM   #15
Anyone have any idea about how Jeff Bīs Solstice handels compared to the Nomex? Because very weak exchange rate and weird pricing over all they have about the same price here.[/QUOTE]
Hi Smoothy,
If you like your ZR71 speakers, why not adding the bass section of the Jensen Seas to your speakers crossed with an active crossover ?
Jenzen CA
See also Intro section Ellam 2 way -> 3 way conversion
Ellam-FLEX-3W
In a second time, you could build the top section and change the tweeter or adapt the crossover for the 27TDFC.
BR Pascal
Old 18th June 2019, 04:46 AM   #16
LineSource is offline LineSource  United States
LineSource's Avatar
Originally Posted by Smoothy View Post
Anyone have any idea about how Jeff Bīs Solstice handels ?
The Solstice is a 2-way TMM design with the crossover at 1,700Hz, which is a 8" wavelength with a 11" center-to-center between the tweeter and bottom midrange. Xdir simulations show a lobing pattern which creates concerns. The modest efficiency of the midrange favors wiring both in parallel as a 2-way TMM or MTM.
Any independent polar measurements available for the Solstice?
Old 18th June 2019, 04:54 AM   #17
AllenB is offline AllenB  Australia
Why wouldn't you include both mids in the simulation?
Old 18th June 2019, 02:03 PM   #18
buggers is offline buggers  United States
buggers's Avatar
I have built one of CJD's designs, and I would recommend his speaker designs.
DIY speaker recomendations, maybe Garnacha?Hide this!Advertise here!
Speaker kit recomendations for aftermarket cabinets(JAMO S506) sonci Multi-Way 3 6th April 2013 11:22 PM
recomendations please falcoron Full Range 3 26th July 2011 02:19 AM
Amp recomendations kzeprf22 Solid State 0 16th December 2008 10:37 AM
DIY Sub amp recomendations?? .::Jonesy::. Chip Amps 17 19th January 2005 07:36 AM
Speaker recomendations Konnan101 Multi-Way 3 2nd January 2004 09:01 PM
Copyright ©1999-2019 diyAudio
