B&C DE-250 FRD & ZMA questions
Thread Tools
Old 11th January 2021, 12:07 AM   #81
sheeple is offline sheeple  Germany
Hi Art,
you are refering to another waveguide, the H290C, which is indeed an OS waveguide like the SEOS (unobtainium), the PRV/QSC (unobtainium) and the 18Sound XT1086 (this features a diffraction mouth and therefore is partly a diffraction horn, also it has some directivity errors). The Eminence H290B is an radial horn, Wayne writes the following about it:
The original H290 was a pretty good device ... It's what I've long considered a happy accident, in that it had very good polars and sounded great in spite of the fact that the curve of the profile was not oblate spheroidal. But the throat shape was close, and the extra expansion towards the mouth acted as a hedge against narrowing beamwidth at the bottom end. It could have used a mouth radius, but other than that, it was a pretty darn good horn.
That sounded good enough for me and I ordered them a while ago. Since, I have learned some more and am willing to further optimize, because: why should I invest a lot of time in something I could do right in the beginning? But at the moment, there is no affordable OS-waveguide available from a European supplier, at least to my knowledge.
Old 11th January 2021, 08:23 PM   #82
head_unit is offline head_unit  United States
Originally Posted by sheeple View Post
H290C...I ordered them a while ago. Since, I have learned some more and am willing to further optimize...But at the moment, there is no affordable OS-waveguide available...
To clarify: you're saying the H290C is very good and close, could be improved from newer knowledge, BUT that nothing improved is actually available?
Old 11th January 2021, 08:47 PM   #83
weltersys is offline weltersys  United States
weltersys's Avatar
Hi Art,
you are refering to another waveguide, the H290C...The Eminence H290B is an radial horn... why should I invest a lot of time in something I could do right in the beginning?
My mistake, the Eminence H290B looks like it would have some HF "beaming" as could be expected from a horn without a diffraction slot where you can't see the driver exit off-axis. Wayne's H290C has the same mounting hole size and bolt pattern...
What is "right" may be difficult to determine in the beginning or the "end"- even though I have a preference now for constant directivity horns, many of my fondest audio memories were from radial horns that weren't.
At this point, with my HF hearing loss, "beamy" horns pointed at me, and away from my partner (she does not have the loss) might work better on average..
Old 11th January 2021, 09:27 PM   #84
EarlK is offline EarlK  Canada
My take on this ( Paralysis through Analysis );
The Eminence H290B is not a Radial ( certainly not by my definition ).
- The H290B is a BiRadial ( in as much as each axis used a différent segment/piece lifted from 2 different exponential curves ).
As Wayne P. mentioned, when the chosen axis segments were married, one axis came pretty close to approximating an OS curve.
No matter how they are classified, they are quite decent sounding horns.
Comically, there were many put-off from buying the PRV 152i Clones because they ( P.E. ) had the temerity to include the word "exponential" in the horn's product description.
People are funny that way
Old 11th January 2021, 09:28 PM   #85
... from a European distributor.
  Reply to this post
B&C DE-250 FRD & ZMA questionsHide this!Advertise here!
Thread Tools
Visaton Quadro questions. Box to Open baffle and other questions. Bas Horneman Full Range 2 1st March 2013 11:53 AM
Driver stage to finals newbie questions - (I hope not dumb questions) rongon Tubes / Valves 15 13th June 2011 09:29 PM
Some Quad els57 questions! - Novice Questions! Fanuc Planars & Exotics 13 5th December 2007 10:26 AM
Questions, questions, from newb DIYer Phatman91624 Multi-Way 41 3rd August 2002 03:52 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
