Old 22nd January 2020, 06:40 PM   #851
mabat is offline mabat  Czech Republic
mabat's Avatar
That's lovely! I only don't understand how to use it
Maybe this would be more intuitive: Superformula - JSXGraph Wiki (if it's correct - the "semi-axes" are acting strange)
www.at-horns.eu
Old 22nd January 2020, 06:56 PM   #852
mabat's Avatar
OK, this is what you need: superformula
- Ah, it is less intuitive than I thought. Anyway, with this desmos chart, everyone should be able to set it up (after a while).
www.at-horns.eu
Old 22nd January 2020, 07:26 PM   #853
mabat's Avatar
Another one tested, almost straight sides - such shape is still of reasonably constant directivity but obviously the sharp mouth edge make it less clean (diagonal polars included).
(Approx 36 x 24 cm)
We can do much, much better now.
www.at-horns.eu
Old 22nd January 2020, 08:04 PM   #854
mabat's Avatar
Yeah, it works.
www.at-horns.eu
Old 22nd January 2020, 08:51 PM   #855
gedlee is offline gedlee  United States
gedlee's Avatar
Originally Posted by Patrick Bateman View Post
So, the DNA array is an elegant solution: NONE of the drivers share the same X or Y axis, hence the smoother response.
But along alpha angle there will still be nulls.
The five drivers is a good idea.
Earl Geddes Gedlee Website
Old 22nd January 2020, 10:01 PM   #856
tmuikku is offline tmuikku  Finland
Send a message via ICQ to tmuikku
Wow mabat, this is really something special for DIY audio community, the deed of the decade!
Old 23rd January 2020, 12:17 AM   #857
Dave Zan is offline Dave Zan  Australia
Originally Posted by gedlee View Post
...there will still be nulls.
This points out a weakness in the "spinorama" (CTA 2034 standard) that it only measures on the horizontal and vertical axis so "dirt can be swept under the carpet" i.e just pushed into the unmeasured diagonals.
For instance it seems possible that the JBL M2 beaky horn may do this.
Are you still in contact with the people involved with speaker measurement standards?
Have you discussed this or considered it yourself?
Any idea of how I obtain a copy of the new standard update (CTA 2034B) to see if it's been addressed?
Best wishes
David
Old 23rd January 2020, 04:02 AM   #858
mrk7 is offline mrk7  Australia
mrk7's Avatar
Originally Posted by mabat View Post
Superformula!
From now on it is possible to define a superformula (see wikipedia).
The download: www.at-horns.eu/release/ath-4.4.1.zip
Incredible!! Thanks!
Old 23rd January 2020, 04:20 AM   #859
Ro808 is offline Ro808  Netherlands
Best wishes
David
You can't, Project R3WG1 (ANSI/CTA-2034-B) is still a work in progress.
The current standard "2034-A" is attached, as well as some related documents.
Old 23rd January 2020, 04:50 AM   #860
Originally Posted by Ro808 View Post
You can't...
It is still unfinished yes, my point was that unfinished standards are often open to public comments before they are finalised.
No use to finalise a standard and then discover that it has flaws.
And I expect the standards committee would send it to some "elder statesmen" of the field for comment, maybe Earl.
I already have CTA 2034A but the other attachments look of interest, thanks.
Maybe more comments after I read them carefully.*
Flaws in the standard are of more interest now that Marcel has provided us with tools to manipulate not just vertical and horizontal polars.
Best wishes
David
*Hmm... the third one (from Sausilito Audio Works) is inconsistent with the CTA 2034A standard, despite the fact it is referenced
I had read it before but never noticed the inconsistency.
The Klippel paper will take time to study, as usual with Klippel stuff.
Easy horn (Eazy Horn) still work? Alternatives? Soldermizer Subwoofers 2 4th March 2014 06:01 PM
For sale: Sound easy V18 & Acoustic-dimension stepped attenuator Tazzz Swap Meet 8 3rd November 2012 09:00 AM
easy exponential horn speakers anyone? 12345chris Full Range 9 21st March 2012 12:32 PM
Easy horn, quadrant horn? Hentai Multi-Way 2 29th January 2012 09:50 AM
An easy to build classic horn? dabbler Multi-Way 22 1st September 2011 09:01 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
